Question about SanDisk Sansa m230 MP3 Player
SanDisk Sansa M230 Problem:When connected to my PC and try to open system says " this device is not formatted. Do you want to format it now?" . If "yes" is selected then system says it can not be formatted.
Posted by sujit_vengur on
Wale Sarumi KomputerSolution
  • 6,993 Answers
Connect your SanDisk Sansa M230 to your computer again. Ignore the format message and go to My computer icon on your computer, right click on the drive (E:or F: or G: etc) representing your SanDisk Sansa M230, scroll to format allow it format from there.
If it still refuses to format, you can the reset the SanDisk Sansa M230and try again.
In case you don't know how to reset your SanDisk Sansa M230, read the info on the below link on how to reset your SanDisk Sansa M23;
http://www.fixya.com/support/r6977146-reset_different_models_version_san_disk
I hope this helps.
Good luck.
Posted on Feb 22, 2011
Nothing is bieng downloaded on my sansa m230 mp3
you need to format it via pc format the device fat file system
Nov 15, 2009 | SanDisk Sansa m230 MP3 Player
By mistake formatted all Data including software
The software is only for Windows 98 otherwise the player is a plug and play device (Windows 2000, XP & Vista). Click here if your operating system is Windows 98.
Can you see the MP3 player on device manager?
Jul 28, 2009 | SanDisk Sansa m230 MP3 Player
Album and genre control
Your USB settings are wrong. In the menu, select MSC for the USB and not auto detect. xlthim
Jul 20, 2008 | SanDisk Sansa m230 MP3 Player
Unable to format
Try quick format, it should work...!!! Else use DOS to format..!!!
Feb 10, 2008 | SanDisk Sansa m230 MP3 Player
Sansa m230
It sounds like there is a problem with the firmware...call sandisk and have them do a firmware upgrade on the device...once you do that it should fix the problems you are having right [email protected]
Dec 16, 2007 | SanDisk Sansa m230 MP3 Player
Sansa says full but there is no files located....
You should format the device thru My Computer, rather than Windows Media Player.
FORMAT: My Computer>Device Name (m230)>Right Click and select format.
This will erase everything on the device and you can start anew.
Best of Luck.
Oct 21, 2007 | SanDisk Sansa m230 MP3 Player
Can not delete songs
If its not showing up, try changing the mode on the device.
Settings>Mode or USB>Change to the other mode.
Connect to your PC. If it shows up, format the device.
To format in My Computer>Device (m230)>Right Click and select format.
Best of Luck.
Oct 14, 2007 | SanDisk Sansa m230 MP3 Player
My sansa is driving me crazy
Try connecting it without the battery. If it shows up, format it. To format My Computer>Device Name>Right Click and select FORMAT. Please add to the question if that didnt work. Best of Luck.
Oct 02, 2007 | SanDisk Sansa m230 MP3 Player
SanDisk Sansa m230
How did you transfer the music? If they are not viewable on the device, you might try updating the firmware. Otherwise, I would format the device and drag and drop the files manually thru My Computer. * format - right click on the device in My Computer, and select format
Sep 10, 2007 | SanDisk Sansa m230 MP3 Player
My Sansa m230 Won't Work!
Try connecting the device without batteries. If it shows up try formatting the device. Right click on the device in My Computer and select format. Best of Luck.
Sep 05, 2007 | SanDisk Sansa m200 (2 GB) MP3 Player
SanDisk Sansa m230 MP3 Player Logo
309 people viewed this question
Top SanDisk Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
