Question about GE JE1590 Convection / Microwave Oven
My JE1590 BH 02 is only 5 years old and we are having door issues. The door will not open, unless while pushing the door button you also hit the door. It seems the latch is not functioning correctly. Any insight?
Posted by pelicanprope on
Anonymous
    Brigadier General:
  • 8,909 Answers
Door catches.
One of the latches may be bent/misaligned and is not lifting the other latch clear of the housing. Remove from any power source, remove the cover of the cabinet. Slacken off the clamp mechanism and ease the clamp over the guide to allow the door to open. When a new door lever is in place, the door may be easily adjusted by slackening off the screws that clamp the door catch/actuators in place whilst holding the door closed and then tightening the screws. The rear of the door may be adjusted by slackening the lower door hinge screws and adjusting as required.
I hope that helps.
Posted on Feb 22, 2011
Push button for wes1452sp1ss
I bought this model 2 years ago.it broke in one vear .I took it back to walmart they replaced it .now one year later it is broken again.It is made cheap .no way to fix mine. steer clear of ge products unless you want to buy a new one every year.
Our LG microwave (LMA 1560SW?LMA1560SB) has a door that won't open. The open button will push in, but not release the door - the plastic button cover pops back out, but just the cover - not the whole...
Mine did this too. Also, at times when I would shut the door, the whole keypad would go dark and the clock would have to be reset. There were also times when I would push Start and it would do nothing. I'd have to unplug it so it would reset itself.
I used a screwdriver and forced the door open. Mine is about 2 years old and it's now dead. Biggest piece of junk I've purchased in years. Really ticked me off, no more LG products for me. I had a Toshiba that lasted me 22 years and the only thing that went bad on it was the light stopped working and the fan cover fell off.
Panasonic Counter top Microwave model # NNT695SF Often when I push the start button, the microwave will go for a few seconds and then cut out. I then open the door and then shut the door and push the...
Issue with your Main Panel Power Fail to innitiate ..Du to Component mal-functioning inside the unit ...Possibility Magnetron defect, Or main Transformer Over heat, Also check for safety swich on the door for bad connection...
1helpful
I have a 10 year old MH7130XE Whirlpool microwave oven. The oven and key pad both work, and the oven heats just fine. The problem is the oven begins running as soon as you open the door...without pushing...
I'm assuming you mis-typed and meant the oven begins running when you SHUT the door and stops when you OPEN the door. Please tell me this is what you meant! If the microwave oven runs with the door open, UPLUG IT IMMEDIATELY AND DO NOT USE IT!!!
If the oven begins running without pushing the start button then the controller is bad or the Start button is worn out and making contact without pushing it. (Most likely it is your controller.) Generally, it is not worth the cost to replace the controller on a 10 year old microwave. Probably time for a new one.
But if you want, you can call Whirlpool and see what they suggest at 800-253-1301.
If this was helpful, please select YES to the first two RATINGS questions. Good Luck!
Sharp Microwave model R-1850A door won't open
buy a boddle of WD-40 and try spray some in the raded spots.Im not a big specialist in microwaves.hope it helps
GE Profile Microwave - door wont open
The only mode to service the door lock is the removing the lid. The screws are located in the back side and on the bottom of the oven.
First unplug the main supply !
5answers
Microwave shuts off by itself
The microwave has a safety door switches (2-3 micro switches)
The door mechanism should hit these micro switches. If you can open the machine, you can see that these micro switch has a holder that you can adjust and tighten to make sure that the hook of the door should activate them.
Sharp Carousel Model R-510HKF (Less than 3 years old) only turns on only when you push button to open door
This is usually caused by either a bad door switch or a loose door switch mount.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://www.searspartsdirect.com
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
Unit Electrical Problem
If it blows the fuse as soon as you hit the START button, it's almost certainly a shorted high-voltage capacitor.
If it blows a few seconds after you hit the START button, it's probably the high-voltage transformer. You'll possibly also smell a faint electrical burning smell from the rear vent after you shut if off.
Microwave can be very dangerous so it is best to have it looked by a professional
Would appreciate a solved rating for expert advise.
GE JE1590 Convection / Microwave Oven Logo
Top GE Microwave Ovens Experts
Paul Bade
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
