Question about IBM ThinkPad R30 2656 Notebook
When i want to install win7-ibm thinkpad r30-2656 i cant see the hdd
Tanuj Handa
    New Friend:
  • 66 Answers
Dear User,
I would like to share with you that this is an old laptop which does not support Windows 7. To have teh best compatibility and performance I would suggest you to install Windows Xp.
Regards,
Tech_Comp
Posted on Feb 22, 2011
IBM Thinkpad i series Click Of Death
Go to this site and you can find what you want
www.shopping.com
1helpful
I Have An Ibm Thinkpad T60 2007-4AU. Restore Disks anyone?
Hi, During the boot at the THINKPAD SCREEN press the Thinkvantage key ( Blue button ) it will launch rescue and recovery and allow you to reboot factory. This only works if you did not corrupted/deleted the rescue and recovery hidden partition on the HDD. Otherwise you will need the rescue and recovery CD to proceed. IBM/Lenovo support should be able to provide you the CD. Might be a defective hdd aswell, in this case to make sure you can run a DFT test, www.google.com -> Look up for " Test DFT " ( Drive fitness tool from hitachi, will make an hardware diag if hdd failure - error code 0x00 = everything fine, other code = Issue - You can look up for accurate code explanation on hitachi website ) thanks and have a nice day J-
Ibm thinkpad r60 hard drive not recognized by
make sure your operating system having a sata drivers,if u r using sata HDD,try to install vista or 7 it show HDD but if you run XP it not detect HDD because XP dont have sata drivers,or burn XP using Nlight software add sata drivers in that
2answers
I HAVE LAPTOP IBM THINKPAD T30 AND I WANT TO CONNECT HARD DISK 80GB OR MORE
  • Supported HDD thickness:
    • 12.5 mm for systems without the touch pad
    • 9.5mm for systems with the touch pad
  • Standard 20GB, 40GB, 60GB HDD sizes.
    Note:
    • The 60GB HDD orderable as marketing option part number 08K9688 has a height of 12.5mm and will not fit in the HDD slot of the systems with the touch pad installed. For these systems, it is only supported via the ThinkPad 2nd HDD Adapter for the Ultrabay 2000.
    • The 60GB HDD orderable as replacement service part number 08K9833 is 9.5mm.
  • Supports one additional HDD which can be used concurrently to offer expanded storage utilizing the Ultrabay 2000
  • S.M.A.R.T technology to issue an alert if a hardware failure is pending
  • ATA Bus Interface
  • 4200 or 5400 rpm
  • Although you can upgrade the HDD, it is not designed to be removed and reinserted on a regular basis. Repeated and frequent removal, for purposes other than to upgrade for greater capacity, can cause damage to the system. The Ultrabay 2000 HDD adapter is designed to provide this flexibility with a second HDD in the Ultrabay 2000 IBM says. I say if the OS recognises it and so does the BIOS, you're good. good luck, hope this helps.-jmattes p.s. I found this info on: http://www-307.ibm.com/pc/support/site.wss/MIGR-42218.html
X41 HDD size limit
Yes you can install more memory capacity harddisk easily.
You get not effect on performance
IBM r52 thinkpad laptop hdd compatibility issue
Download Hiren CD .. format the hDD and install the OS Freashly
2answers
New harddrive
Check the connections and the drive settings (jumpers) to make sure its set to "Master, Stand alone". The IBM PC's autodetect's the HDD installed so if it doesn't read the HDD, there is a hardware problem.
Maybe is the Thinkpad interface faulty and the HDD you replaced is fine.
IBM ThinkPad T23 Can't install Windows XP
Download THIS program and burn it to cd.Start pc with cd-rom and look for ARAONIC program.With that program you can repair your hdd couse the problem is HDD!
IBM ThinkPad R30 2656 Notebook Logo
Top IBM Computers & Internet Experts
Ekse
Michael Thomas
Michael Thomas
Jax Planet
Jax Planet
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
