Question about Dell Inspiron E1705 Notebook
The new adapter is not compatible with the battery more info: laptop-batteries.com.au
Posted by joan2012 on
biian l
    Novelist:
  • 184 Answers
The following three condition should be met for you to use an AC Adapter safely.
1) Output Voltage is within +/- 5% of your old charger's output.
For example, if your old charger provides 19.5V, then you can use a charger that provides 20.5V or 18.5V.
2) Output Current is the same or higher than that of your old charger.
For example, if your original adapter provides 3.42 Amps, then you can use a charger that provides 3.42 Amps, 3.9 Amps or higher.
3) Connector tip must fit securely into your laptop.
Specification of Dell Inspiron E1705 AC Adapter:
Output: DC19.5V 4.62A
Power: 90W Max
DC Connecter (Barrel) size:
Internal Diameter: 5.0mm
External Diameter: 7.4mm
With central smart-pin
Reference: http://www.chargerbuy.com/replacement-dell-inspiron-e1705-ac-adapter-19-5v-4-62a.html
Posted on Feb 23, 2011
robert roberts
    Sergeant:
  • 302 Answers
You will need a genuine dell charger and look on your old one to see what pa it is if it says pa-12 then you need the same one again
Posted on Feb 22, 2011
Toshiba satellite 1900 wireless network adapter?
just use a usb wireless adapter
http://www.netgear.com.au/home/products/networking/wifi-adapters/a6200.aspx
802.11ac is the new wi fi tech and is downward compatible with 802.11b,n,g wireless systems
or just get a 802.11n if you do not want fast wireless speed capabilities in the future wi fi systems once places upgrade their wireless systems
http://au.element14.com/lm-technologies/lm006/wifi-usb-nano-adaptor-150mbps/dp/1790361?ost=1790361&mckv=s'pcrid'59148083448&CMP=KNC-GOO-SHOPPING-1790361&CAGPSPN=pla&gclid=CJuvrvrn_ccCFdgmvQod_FUA6w&CAWELAID=120185580000118521&gross_price=true
Sep 17, 2015 | Toshiba Satellite Computers & Internet
Tip
HP Pavilion dv9000 battery tips Your new HP Pavilion dv9000 laptop battery comes...
DV9000 DV9700 DV9600 HSTNN-IB33 laptop Battery Chemistry : Li-ion
Voltage : 14.8V
Capacity : 4400mAh
Corlor : Black
Original Price: US $85.63
Special Price: US $65.63
warranty.jpg * 1.One year warranty, 30 days Money Back.
* 2.Brand new, 100% Q.C. of every battery.
* 3. Highest quality Japanese battery cells.
* 4. Guaranteed to meet original specifications.
* 5. 100% secure and safe.
  • Shipping: Our laptop batteries are shipped by USPS.
    The battery have a good compatibility with many original laptop batteries for many laptops, even diffenent brands.
  • Descriptions of Hp DV9000 DV9700 DV9600 HSTNN-IB33 Battery 1. 100% new high quality Replacement DV9000 DV9700 DV9600 HSTNN-IB33 laptop Battery Compatible Li-ion Batteries.
    2. This Hp DV9000 DV9700 DV9600 HSTNN-IB33 battery can be used for the other models and battery part No.
    3. 30-Day Money Back,1 Year Extended Warranty for Hp DV9000 DV9700 DV9600 HSTNN-IB33 laptop Battery.
    4. Great After-sales Service Department for laptop battery, fast respond to your request!
    5. Fast delivery if you order the Hp laptop battery.
    6. Need any assistance on DV9000 DV9700 DV9600 HSTNN-IB33 Laptop Battery, please feel free to email us!
  • on Jan 27, 2010 | Computers & Internet
    I purchased a battery from atbatt.com that said it was compatible with my inspiron 9400. It must be good because my computer will power on with it. I also purchased a new targus charger from Wal-mart which...
    Hello.
    Return your power adapter to Walmart and replace. I'd suggest taking the laptop with you to further test in the store with the adapter you buy. Be certain that the new power adapter is compatible with the specific Dell Inspiron notebook series that you own.
    Hope this helps.
    Dec 24, 2010 | Dell Inspiron E1705 Notebook
    Http://www.batterylaptoppower.com/toshiba/pa3537u-1bas.htm Shorter battery life notebook, notebook battery can not be used, laptop battery suddenly power...
    First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
    If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
    If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
    If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
    Aug 25, 2010 | Dell Inspiron 2200 Notebook
    My new compatible battery 02K6626 is not charging in my T20.
    You can buy a completely compatible IBM ThinkPad T20 battery. Search in Google for the model of you wanted battery,then you always can find some best online laptop battery shop which have a high fame and have running for some years ,they provide both good batteries and service.
    Apr 29, 2010 | IBM ThinkPad T20 2647 Notebook
    Acer Travelmate 4060. Dead. Flashes power/battery led once when I hit the power button then nothing
    Try removing the battery and plugging the machine in as if you were going to charge it, then try starting it up.
    If it doesn't start up, check the connections on the adapter. If everything looks fine then theres a possibility that you have a broken adapter.
    Mar 30, 2010 | Acer Aspire 4520-5582 Notebook
    How about this Pavilion dv8000 Battery for HP Laptop Battery?
    You just write down the details about HP pavilion dv8000 battery, I know two websites have cheap HP pavilion dv8000 battery
    http://www.cheap-laptop-battery.co.uk/laptop-batteries/hp-pavilion-dv8000-series.htm
    http://sales-battery.com/laptop-batteries/hp-pavilion-dv8000-series.htm
    Jun 02, 2009 | HP Computers & Internet
    Can I use ther Targus Adaptor for Inspiron 1525
    On the long term, a power adapter with a bigger amperage can damage battery and battery charger.
    Better to get an adapter with same specs as the 65/70W one , or an original replacemant:
    Dell Inspiron 1525 New AC Power Adapter Supply $14.29 - Buy.com Dell Inspiron 1525 65 Watt Original AC Adapter $25.00 - parts4nb.com Dell Inspiron 1525 Power Cord PA-12 $16.95 - AmeriMax Advance
    DELL Inspiron 1525 DC Power Laptop Adapter ... £25.23 - B2C Shopping UK DELL Inspiron 1525 Laptop AC Adapter power adapter £38.99 - Very Good Battery Dell Inspiron 1525 Ac Adapter Charger Power ... £16.50 - eBay UK
    AU/NZ - DELL INSPIRON 1505 E1405 E1505 AC Adapter Power Supply
    Dell : Lind Electronics 70-Watt DC Power Adapter for Dell Inspiron
    Apr 22, 2009 | Dell Inspiron 1501 Notebook
    Dell Inspiron E1705 Notebook Logo
    190 people viewed this question
    Lee Hodgson
    Lee Hodgson
    efs_perpends
    efs_perpends
    Michael Thomas
    Michael Thomas
