Question about HP LASERJET P1006 Printer
HP LaserJet P1006 says "out of paper" Cannot find
Posted by lissabeth4 on
Brandan Heasley
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 49 Answers
Clean off the roller. It may not be detecting the paper due to debris on it
Posted on May 31, 2019
5 Related Answers
Soulvisitor
Soulvisitor
  • 1113 Answers
SOURCE: HP LASERJET 4250n PRINTER-PROBLEM WITH PAPER JAMS AND "FUSER ERROR"
Put a maintence kit in your machine, easy install, everything just clicks in, Every 200 000 prints it should be done, it includes the fuser, all feed rollers, sep pad and transfer roller.
These are great printing machine, they only ever need the MK and on this model a fuser drive gear wears and get noisy, but once that has been done once, it is ok from then on.
KIts seem expensive but they are meant to last 200 000 prints and usally do. These are one of the best most reliable printers in the market.
fee693c.jpg LINK to part info
Posted on Jan 09, 2008
Anonymous
  • 43 Answers
SOURCE: hp laserjet 4250n paper jam in 13.01.00
According to the manual: "A 13.01.00 error message indicates that the media did not arrive at the pre-feed sensor (PS102) within the specified time." That usually means that the rollers fail to pickup the paper from Tray 2. Usually, cleaning the paper feed roller in the 500 sheet tray should fix this. While blowing out dust, you may have coated this roller with paper dust. A quick way to double check this is to power cycle the printer & try to print from Tray 1, the MP feeder tray (unless Tray1 has rarely or never been used...it might be a little tempermental as well). Regardless, this error is very common & is usually fixed by cleaning. Depending on usage, this roller is considered a customer replacable item (Part # RM1-0037-000CN) with a life expectancy of more than 200,000 pages. There are 3 of that type roller in the printer, but the one in the tray is usually the 1st one to fail. Hope this helps!
Posted on Jun 02, 2008
Anonymous
SOURCE: paper jam HP Laserjet 3050z
Open tray 1 and pull any visible jammed media out of the all-in-one.
If no media is visible, open the print-cartridge door, remove the print cartridge, and rotate the
upper media guide. Carefully pull the media up and out of the all-in-one.
Close tray 1.
Posted on May 04, 2009
Anonymous
  • 58 Answers
SOURCE: hp p1006 wont load/feed paper
Mine does the same thing. The solution I have used on several occasions is to load it as full of paper as possible without forcing it under the guides. Lift the lid to reset the jam function, then when it begins to try to print, push the top one or two sheets of paper into the printer. If it will grab them and print then it will be ok for the whole stack of paper. Adding more paper before it gets too low also seems to help.
Posted on Jun 05, 2009
SOURCE: Error 13.20.00 on HP laserjet 5200 jam inside top
This is a common issue and most times a bear to repair. There is a sensor flag mounted on the paper feed assembly behind tray 1 which has a habit of either coming off or the spring which moves it back a forth comes out of its holder. In any case it is one of the worst repairs you have to do. Many items have to come off to get to it and getting that flag and spring on correctly even with the instructions is difficult. Usually what will happen is you get the 13.20.00 error on power up with no motor movement and when you open and close the top cover, the motor will move but the same error reappears. If you are lucky it is just a case of a shred of paper blocking the sensor flag from moving and worst case of the flag having come off. You will need the service manual and check the removal and replacment section on the paper feed assembly and play close attention to the 3rd page.
sometimes this error also appears if a wrong fuser is installed in ur printer that is not ur model number.... have it checked
thank you have a nice day
Posted on Aug 10, 2009
Testimonial: "Good answers - unfortunately still no closer to solving the problem."
Hp laserjet 1005 printer second page paper jam
Hi senthil, my name is Lisa and I would be happy to help you with your Laserjet 1005. I understand you are experiencing a paper jam when printing multiple page documents.
There are multiple variations of the 1005, below I will list 3 links one for each of the 1005 Laserjet printers I think you could have.
Clearing Paper Jam for HP LaserJet P1005 P1006 P1007 P1008 and P1009...
http://h20565.www2.hp.com/hpsc/doc/public/display?sp4ts.oid=1839458&docId=emr_na-c00765431&docLocale=en_US < HP LaserJet M1005 MFP - Clearing jams
http://h20564.www2.hp.com/hpsc/doc/public/display?docId=bpl10965 < HP LaserJet 1000 Product Family - Clearing Printer Media Jams
I hope that one of these links is specific to your printer, and that the appropriate link helps you resolve the issue.
Best of luck. I work on behalf of HP.
Jul 02, 2015 | HP Office Equipment & Supplies
Paper jam and we cant see the paper
open toner door pull out the toner ,now remove the paper.
May 25, 2015 | HP LASERJET P1006 Printer
Free install drivers for hp laserjet p1006 printer
Click Here for the drivers for the HP P1006 laserjet printer, just make sure you know your operating system... Hope this helps and if so please mark as FixYa!!
Aug 28, 2010 | HP LASERJET P1006 Printer
Wont load paper
without taking it apart its hard to tell whats wrong. But you can remove the toner cartridge and un plug it. Pick it up and gentley shake it to see if there is some debre in it. Steven
Jan 21, 2010 | HP LASERJET P1006 Printer
My hp printer says there is a paper jam and there is not any paper in it
There is a small piece of paper stuck under the sensor at the rear of the input unit.
Oct 01, 2009 | HP LASERJET P1006 Printer
HP LASERJET P1006 Printer Logo
561 people viewed this question
Ekse
efs_perpends
efs_perpends
