Question about Canon ImageRunner 2020i Copier
Sir I have Canon IR 2870 a few weeks later machine shown Error 000007-000. I changed the fixing film but machine showing error again why
Posted by Mahendra Malviya on
P V ramu
    New Friend:
Sir I have canon 2870 machine. The machine giving the finisher problems, when starting the finisher going down. The machine showing the problem E540. Please kindly solve
Posted on Jun 09, 2011
Santosh Pattnaik
    Habit-Forming:
    New Friend:
  • 75 Answers
Clean the white mark reader in the fixing unit and check the harness of the fixing unit.
Posted on Jun 28, 2016
Canon tech CROATIA
  • 1,219 Answers
Hi, check/reconnect the sensor above the fixing assy, or change sensor.
Posted on Feb 23, 2011
How to Clear Error- 000716-0010 in Canon IR2870 Copier?
E716 - There is an error in the communication with the pedestal.
After the presence of a pedestal has been detected, the communication fails to be normal for 5 sec.
1. Check the cable. Replace the DC controller
2. PCB. Replace the pedestal drive PCB.
http://www.smoothprinterservice.com/
Sep 22, 2014 | Canon Ink Cartridge GPR15 for iR 2270, iR...
How do I solve Error Code - E000716-0010 In Canon IR2870
Failure of the communication with the 2-way unit
Description
When the communication with the 2-way unit is faulty after detecting the connection with the finisher.
Remedy
1.Install the 2-way unit.
2.Check the cable.
3.Replace the DC Controller PCB (PCB4).
4.Replace the 2-way unit driver PCB.
2870 canon copier machine showing error code E000024-0001
remove your doveloper unit and check sensor, it is luse or re fix again ,........
Sep 24, 2013 | Canon Ink Cartridge GPR15 for iR 2270, iR...
May canon ir 2870 eror code below E000732-0010
sir ihave ir 2870 mashine . the machine giving E000225 -001 error code
Oct 25, 2012 | Canon imageRUNNER 2870 Copier
E000000-0001
Okay, to be of real help you have to reset the error in service mode as the officetech1 said. To do this you need to press the head key (the head with the star inside) then 2+8 together and then the head key again. This will get you into service mode. Then select 'COPIER' then 'FUNCTION' then 'CLEAR' then select 'ERROR' or 'ERR' press 'OK' then switch the machine off and on again. This may get it working for a while or a long time. But if not, you will need a fixing film unit to remedy the problem.
Mar 10, 2009 | Canon imageRUNNER 4570 Copier
Canon iR-2016 System erro E007
The erreor code E007 has to do with the fixing ***'y upper film ***'y or roller. It is saying that the film is not moving in and out of "HP" Most of the time it means that the fusing film is torn and not moving properly. If you are getting paper jams in the fusing area and or unfixed or smeared copies. You most likly need to have the fusing film ***'y replaced. It could also be that it is out of place and needs to be readjusted. The only problem is that it's a little tricky to get to and not a bad idea to have a new film to replace the old one while you have it out. Good Luck
Mar 15, 2008 | Office Equipment & Supplies
hi how do solve this problem system error E007
Dec 04, 2007 | Canon CLC 1140 Copier
543 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Ekse
