Question about Samsung Televison & Video
My samsung plazma tv has sound but. No picture what is the problem
Posted by benlohrer on
Jerry Umali
  • 979 Answers
Hello Sir, Hi, its the inverter board that powers the back light. this needs replacement. the board can be purchase online. try www.usefulparts.com and find your model TV under manufacturer. If the board is available, have it installed by a technician.
Posted on Feb 22, 2011
  • Dan Davenport Mar 03, 2011
    If it is a plasma TV it won't have a back light or an inverter, that is only on an LCD TV, it is more likely the power supply or the YSUS board. Plasma's are difficult. High voltages and currents and one board blows and takes others down with it. I am quite confident with electronic stuff but I have been beaten by a plasma and won't fix them now (Till I get some training!) BE warned!
  • Todd Hill
    Todd Hill Jul 09, 2011
    plasmas do not have an inverter pcb.. really? or backlight ck voltages out of pwr supply ve,vs,va vces, rly on high ms on high would look at startup v-sus signal ramp up ramp down
Sean Michael
    New Friend:
    Problem Solver:
  • 16 Answers
As with other post where the detail of the make,model,series,ect. are not given this is a short generic description for Plasma screens. First of all as the plasmas tend to be relegated to the large screen environment. LCD's have only recently begun (era 2009-2011 ) to be manufactured in quantities with sizes larger than the 32"-42' sizes.
The Plasma and LCD apparatus are two very different pieces of equipment which accomplish the same task. The myths and misinformation abound for the operational phases of both . ie;
Dark picture with sound on a LCD would usually represent an inverter or back light failure.
Dark picture with sound on a Plasma ( which do not utilize the inverter / back light setup ) could represent a partial failure of the main power supply, an out of range video signal, thermal shut down of one or more power/regulators in section/group boards after the main power section/group board. Such as leaking/blown capacitors ( yes remnants of the capacitor plague are still with us) on the Video Group output section. In the afore mentioned scenario , the video would fail but the sound which is a separate circuit, group, and power rail would continue uninterrupted.
Plasmas like LCD are not mythical, rocket science, or magic. They just require a knowledge which is not familiar. A schematic or block diagram is a good start. A thorough knowledge signal circuitry and power circuitry help.
Where as I am awaiting approval under "fair use" to use a plasma schematic particular to a known brand, I cannot upload the item at present. I am currently seeking a good generic diagram/roadmap to illustrate the general layout in hopes making this a little easier to visualize.
Doc Michael
Posted on Mar 07, 2011
My 42 samsung plasma tv lost picture
hello i have a 42inch plazma pdp42v6 check all caps ok
all board ok sound ok but no picture can anyone help me
fix this problem please
Dec 21, 2012 | LG RU-42PX10 42 in. HD-Ready Plasma...
My 42 inch plazma turns on but ther is no picture
my ESA 42" plasma tv turns on no picture and no sound.
Jan 30, 2010 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
I have a Samsung HP-T4264 plasma tv with a badly cracked screen. Can this screen be replaced with one from a Samsung HP-R4252C plasma TV.
No way, Jose!
Those bastards manufactures are always making sure you won't be able to use parts from one model to the other. Especially-display! LCD panels could be rigged, but no plazma's. Sorry!
Sell it for parts to some repair shop and get yourself LCD or LED panel. Plazma is gone!
Jan 21, 2010 | Samsung HP-T4264 42 in. Plasma HDTV
Shows no picture but has sound its a tedelex 42 inch
if you had no prior ideas about plazma tv . then call to some experienced person so that he can help you. oterwise take to the repair center .
Dec 07, 2009 | Philips 42HF7444T 42 in. Plasma TV
Picture went out on p50hdm Vizio Plazma tv after loud POP
It's either the backlight lamp or backlight inverter is busted due to a power failure or fluctuation. Here's how to determine which is which:
  1. Grab a flashlight.
  2. Turn on the TV.
  3. Shine the flashlight onto the screen.
  4. If you cannot see any display even a faint one, the backlight inverter is dead, else the backlight lamps are busted.
  5. Replace which ever is the culprit.
Sep 26, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
When Playing Halo 3... The Screen Shrinks Down...
kyleolver,
16:9 is the widescreen mode, the other size is 4:3 ratio which is what the game's native size, it is picture boxing by the plazma is showing the size as not to distort the image, to get the full screen picture, but make sure it's not the plazma's setting first - where it selects the size of the image, you may have the streched version on your normal play.
randy320sgi
Dec 21, 2008 | Samsung HP-R4272 42 in. Plasma HDTV
Samsung hpr4252x perfect picture in
You have a burn in problem from watching widescreen movies.If you have access to a signal generator or tv setup disc run a perfectly white screen on the plasma for about 30 min.This should help even out the pixels on the display.
Mar 05, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Changing Screen Size on Samsung HP-R4272
you must not have the correct picture settings in the cable box, as although they are not HD they will still be widescreen, so check both tv and box for picture settings.
Oct 14, 2007 | Samsung HP-R4272 42 in. Plasma HDTV
Televison & Video Logo
488 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Ekse
