On startup press F11 to launch System Recovery or look for Recovery Manager in Windows Enviroment, but before trying this, since it formats the hard disk, it should be a good idea to back up all your data into an external hard disk or USB disk with enough capacity.
You will need to format the hardrive. This means you will be erasing EVERYTHING on the hardrive. Before you do this though, you will want to make sure that you have the restore disk and system disk which should have come with your computer. If you don't have these disks do not attempt this, you will end up with just a big paper weight.
Have you tried using the "restore" option in accessories? This will restore your computer back to an ealier checkpoint without losing the operating system and drivers. I would try this first.
Hope this helps
3. Restore complete system menu. From the left menu of Vaio Recovery Center select "Restore complete system"
4. Start button.
5. Select "Restore C: drive" and hit Next.
6. Read the information on this new window, select "I understand" and hit Start.
7. "Are you sure?" If you made backup for all your data and really want to restore your Vaio as it was when you bought it you have to make sure that have it plugged in to a stable source of energy and press YES.
8. So ... next you should sit back and relax. Your computer will start showing the next messages
Shuting Down
Windows is loading files ...
Restoring your operating system
Please wait a moment while Windows prepares to start for the first time...
Windows Vista setup: The initial setup may take up to 15 minutes. Do not turn off the computer. Click OK to continue the setup process and wait until the "Set up Windows screen appears". Select OK
9. Take your time until your system install VAIO software
Finish to restart.
10. That's all. Now, your VAIO has the original operating system, drivers and software. Now you have to configure your VAIO as you want.
