Question about Belkin (F5D7230-4) Router (587009)
I cant remember my Belkin password. I dont believe I changed it from when I purchased it though so it should be the standard password
Posted by rca7795115 on
  • Doug H Feb 22, 2011
    What's the router model?
Jeff
    Novelist:
  • 100 Answers
Not quite clear as to your problem. Are you trying to access the web-based configuration page for the router (for which you need an administrator password)? Or are you trying to make a wireless connection to the Internet via the router (for which you need the wireless security key)?
Those are two separate passwords, and you may be able to retrieve them both. The administrator password would be stored in the computer that was used to configure the router. The security key should be in the computer which configured the router, as well as any computer which made a wireless connection to the router.
You may find it helpful to check the owner's manual. If you don't have that available, you can download a copy here:
http://en-us-support.belkin.com/app/product/list/q/routers/
Be sure to specify the correct router model.
If you can access the web-based configuration page for your router, you should be able to view (or reset) the wireless security key. (Check the owner's manual for your model.)
For many Belkin routers, the URL for that page is simply: http://router
Then select "Security", and following the onscreen guidance.
If you're not able access the router's configuration page, and the passwords are stored, you should still be able to retrieve them by installing some free software.
For the computer that configured the router, download and install this program:
RouterPassView by NirSoft
http://www.nirsoft.net/utils/router_password_recovery.html
http://www.softpedia.com/get/Network-Tools/Misc-Networking-Tools/RouterPassView.shtml
For a laptop that connected to the router, download and install this program:
WirelessKeyView
by NirSoft
http://www.nirsoft.net/utils/wireless_key.html
http://www.softpedia.com/get/Security/Decrypting-Decoding/WirelessKeyView.shtml
Posted on Mar 16, 2011
Change my belkin router password want a diffrent password
Connect to the router via a cable.
Open CMD (command) prompt and type:
iconfig
you will see a default gateway listed - write the ip address down.
Open internet explorer and enter the gateway address into the address bar.
Should open a web page to configure the router.
You may have to provide a password.
If you're only interested in wireless password change, select different pages until you get to the wireless stuff.
Try this site:
http://techchannel.radioshack.com/change-security-settings-belkin-wireless-router-1402.html
How to Change Security Settings on Belkin Wireless Router
Feb 11, 2015 | Belkin Computers & Internet
Cant remember my password and i dont know how to change it
Suggest take the Netbook to the nearest Sylvania authorized computer repair shop, and;
1) Proof of ID
2) Proof of ownership, (Receipt of purchase)]
3) Credit card
The tech will obtain a Master password. From there the tech will either put a password on you want, or disable password.
The tech keeps the Master password.
Regards,
joecoolvette
Jan 07, 2013 | Sylvania G-Netbook
Can't remember my password
If you have NOT changed the default password, that is:
Manufacturer Model Protocol Username Password BELKIN F5D6130 SNMP (none) MiniAP BELKIN F5D7150 Rev. FB MULTI n/a admin BELKIN F5D8233-4 HTTP (blank) (blank) BELKIN F5D7231 HTTP admin (blank)
If you have changed it, just reset the router and use above passwords.
Aug 02, 2011 | Belkin Basic Wireless Router
I dont remember my password i cant acces anything
To connect to your wireless router, it needs the router'swireless settings configured ie SSID WPA or encryption key and also thewireless cards in all the laptops and computers needs to be configured withthese router's wireless settings. Then the laptops and desktop computers cancommunicate with your wireless router. To accessthe Belkin configuration, connect a LAN cable from the Belkin to the LAN porton your computer. Open a browser and enter the Belkin configuration URL. http://192.168.2.1 The defaultPW = blank (just press Enter) You can nowgo into the wireless settings to obtain the WPA2 encryption key or change it toa new one.
Feb 26, 2011 | Belkin My Essential (ME1004-R) Wireless...
I cant remember my belkin router password to enable me to connect to the internet with my laptop. What should i do?
The easy way to get password is to left click on Internet access bars near time on computer.When box appears showing wireless connections right click on your name connected to.In drop box choose properties then under security click show characters to reveal password.Hope this helps please rate
Oct 07, 2010 | Belkin (F5D5231-4) Router
We cant change the settings on the wireless router because we dont know the password
there hasn't usually a password on the belkin routers I've used so try leaving it blank. Alternatively, try resetting the router as per the manual and start again.
Apr 28, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Cannot remember what my password is for my wireless router. I want to use a laptop from it. Any ideas?
There are two possible solutions, depending on which password you can't remember. If you remember the password to log into the router, you can go to the wireless security page and see the wireless password (you may have to uncheck the "obscure password" box to see it). If the password you can't remember is the one needed to log into the router, I believe your only recourse is to hold the reset button for at least 10 seconds to restore the factory defaults. NOTE: you will then have to re-configure the router as if you had just taken it out of the box.
Aug 15, 2009 | Belkin (F5D7231-4) Wireless Router
I have a Belkin Wireless adaptor and a wireless router. The netgear adaptor I had before on my desktop got borken so I replaced with a Belkin adaptor. The new Belkin adaptor is not recognizing the wireless...
Hi, did you provide the network key/password when you setup the wireless conection on your computer? Is it detecting your wireless router (you should see your SSID or network name) when you click on your wireless icon (in the taskbar) and chose "show wireless connections". If you can acess to your router via it's configuration page(type the router's default IP address in your browser) you can go check the settings and change the key/passphrase if you dont remember it. If all of this is not working, you can also start from stratch. Reset the router to factory settings (check your manual) then reconfigure it the way you want, put the new infos in your wireless network connections properties and try again. let me know with more specific details if you still cant do it
Jun 08, 2009 | Belkin Wireless Desktop (F5D7000FR)...
Cant remember power-on password
run safe mode. use administrator change password and save. then open administrator again remove password and restart your desktop.
Jun 01, 2009 | HP Compaq d530 SFF PC Desktop
I cant remember the password i entered to protect my wireless from others. is there a way i can retrieve this password without using the disc
Hook up to the router over ethernet
Browse to 192.168.2.1 (Assuming you havent changed Ip Address)
Click Secutiry in the left menu.
Enter Username and Password if required, click submit.
Youll now be able to see your WEP or WPA key
Heres a link to the wireless setup guide
http://www.belkin.com/uk/support/article/?lid=enu&pid=F5D8231uk4&aid=10065&scid=282
Regards
Nick
Oct 28, 2008 | Belkin (F5D8231-4) Wireless Router...
Belkin (F5D7230-4) Router (587009) Logo
132 people viewed this question
Top Belkin Computers & Internet Experts
Mike
Michael Thomas
Michael Thomas
Lee Hodgson
Lee Hodgson
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
