Question about Nikon Cameras
My camera has lines running through the screen. Did I break something?
Posted by rodeos_r_us2 on
Michael OGrady
    New Friend:
  • 22 Answers
Probably not, many digital cameras have the option to display grid lines on the display to make it easier to frame your pictures. Look in your camera manual to see if you can turn grid lines on or off.
Grid lines can help you frame horizontal pictures (like a landscape).
Hope that helps!
Posted on Feb 22, 2011
Bleeding breakes on aprilia sr50 ditech
check for leaks and replace cap or rubber washer under cap
Sep 29, 2012 | Aprilia Motorcycles
I have a Sony A300. When I turn on the live view screen, I only see a bunch of vertical lines on the screen and cannot see anything that I try to display (ie. menu, display, prior photo's, or the...
Sorry to say your LCD screen is cracked, it happens a lot with the Sony DSLR-A300 and A350. The solution is to remove the cracked LCD and replace it with a new one. The repair isn't that difficult, but you have to be careful removing the LCD or you will break a latch holds two FPC cables together and then will have to replace yet another part that takes MUCH more labor.
I did a Google search for "sony a300 lcd repair" and at #2 I saw an online digital camera repair shop that has done tons of this repair over the last few years.
Hope this helps!
Thomas Drayton
Owner, Darntoothysam.com Digital Camera Repair
Jul 11, 2011 | Sony Alpha DSLR-A330 Digital Camera
Drive belts break after 10 mins
could be a few things causing these problems make sure you check all the pulleys have no defects like small chips cracks or dents cus the this tends to cause belts breaking make sure the belts are not to tight or too lose this can cause problems if somethings out of line it will tend to throw your belt off not break
Sep 12, 2009 | Garden
Pictures taken have horizontal lines running through them!?
there is something wrong with your screen. when the pictures are developed... they should turn out normal.
Jul 07, 2009 | HP Photosmart R927 Digital Camera
DCR-DVD105 DVD screen is black.....have sound but no picture
Dear Court1,
Let me know 1st, is there Live Picture in camera mode ok? I mean can you see live scene/ picture in viewfinder?
If NO, problem is in camera section and it has hardware problem.
May 02, 2008 | Sony Handycam DCR-DVD105 DVD Camcorder
Canon powershot SD630
I would definately not "finish" breaking it :)! There are places you can send your camera to have it looked at, and it might be something as simple as a dislodged cable.
This site can do an LCD repair, or can just look at the camera and give you an estimate if you need -
http://www.darntoothysam.com/servlet/the-227/Canon-SD630-LCD-Repair/Detail
Nov 28, 2007 | Canon PowerShot SD630 Digital ELPH / IXUS...
Lines across screen and pictures
This is a CCD break down Panasonic customer support is the place to go If it is a recent purchase they will swap it If it is older they may offer a discount on a replacement
Jan 28, 2007 | Panasonic Lumix DMC-LZ2 Digital Camera
Black pictures with blue lines running horrizontally through them
If you are able to see the picture in the LCD in black color and if there are no damages to the LCD -the LCD is fine. There is a back light panel attached behind the LCD which may be defective.Check for the loose connections. If you need spare parts contact me.
Nov 26, 2006 | Sony Cyber-Shot DSC-P72 Digital Camera
Cameras Logo
147 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you a Nikon Camera Expert? Answer questions, earn points and help others
