Question about Logitech Z-2300 2.1 Computer Speaker System (3-Piece)
One of my speakers stopped working today , the one with the yellow prong . when I plug in the black prong it works in both ports playing the speaker that is not broken . I purchased these new 2 weeks ago . any idea what could be wrong ? thanks
Brian Sullivan
  • Logitech Master
  • 27,725 Answers
Try swapping the speakers around if the problem still persists either the speaker is faulty or
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or click start control panel administrive tools computer management device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
don
Posted on Feb 22, 2011
Where do I pug the speakers in ? I need a Picture,Show me the picture.
    • 1 Remove the Dell A215 speakers from the box. Place the speakers in your computer area. The speaker with the volume knob is the right speaker and should sit to the right of your keyboard. Place the other speaker to the left of your keyboard.
    • 2 Plug the left speaker into the right speaker. The left unit has an orange-brown plug that connects to a similarly colored port on the back of the right unit. The other end of the cord is fixed to the rear of the left speaker.
    • 3 Insert the two-prong end of the power adapter into an electrical outlet. Plug the other end into the black power port on the back of the right speaker.
    • 4 Insert the main audio cable into your computer. This cable is fixed to the back of the right speaker and has a green head. Plug the green connector to the green audio-out port on your computer. This port may be on the front or back of desktops or on either side of a laptop.
    • 5 Turn the knob on the right speaker clockwise to turn the speakers on and increase the volume. Turn it counterclockwise to lower the volume partially or all the way to turn the speakers off. The speakers should work automatically on any computer with a sound card.
Let me know if this solved the problem and good luck..
Sep 09, 2011 | Dell A215 Computer Speakers
The speakers quit working/what do I do?
Make sure that it is the speakers that stopped working by unplugging them from your computer (or whatever you have them plugged into), and plugging headphones into the same jack that the speakers were plugged into.If the headphones work, you have confirmed that the problem is with the speakers. If the speakers use an AC adapter (black plastic cubical thing that plugs into the wall), then you might try getting a replacement AC adapter with the same output (AC or DC), voltage, polarity (which side is positive, and which is negative), and connector. If the speakers plugged into a USB port for power, your USB port may have turned itself off. In that case, reboot the computer to see if the USB port will turn back on.
If none of this works, you have to buy new speakers.
Apr 18, 2011 | HP JBL Platinum Computer Speakers
Just got a new Dell computer. H/K subwoofer from old computer has a plug with three connections that would go in on the computer; green, black and yellow. New speakers plug directly into computer...
Could you please clarify me the subwoofer system from the old computer what brand / model is it?
Waiting clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Sep 18, 2010 | Harman Kardon HK595 Computer Speakers
I have the logitech z-2300 just the other day the
mine did the same thing today , i just bought these new 2 weeks ago . the black prong speaker works in both ports ..
the yellow prong speaker is the one with the malfunction .
it works sometimes but when i turn up the volume louder it dies out .
Feb 23, 2010 | Logitech Z-2300 2.1 Computer Speaker...
My rear sound jacks are blue, green and pink...Im not sure where to plug the three speaker jacks in, as theyre not marked in any way. The speakers seem to be working, except for playing videos etc on the...
what do you mean by your rear sound jack? is that the 3 jacks that you use to connect to your computer ? it depend on if you have 5.1 system or 2.1 system but normally you can plug it in this order : green , yellow , black . The pink normally is for Mic port but if you don't have it then insteed 1 of those 3 colors you replace it with the pink. And again you have to have a software on your computer which is usually come with your computer when you buy it. You'll have to manually configue those port in the software on your computer to get it to work. Good luck and keep me updated.
Oct 22, 2009 | Logitech X-530 Computer Speakers
865G7MF Motherboard. No sound. Drivers updated and device manager reports OK. speakers plugged in properly.
Check the Speakers. Get a Multi-tester, and set it at 1 x 10 Ohms. Speaker plugs have three sections. (Ground, Left speaker, and Right Speakers). Place the black multi-tester prong at end of the Speaker plug while other red multi-tester prong at
the second section. The reading must be zero. With
the black prong steady at the end, place the red prong to the third section. Must be Zero reading.
Otherwise, you have to buy a replacement.
Oct 14, 2009 | Computers & Internet
No sound from speakers when in rear speaker port
you need to download the drivers, or check the volume control on the quink lanch in the right hand counter
Feb 14, 2009 | Dell 5650 Computer Speakers
Only 3 speakers work!
I took the bottom off my go play to have a look inside, the internal port is connected to one rear speaker grill and the other is blanked off, so no sound will come out of that one.
Dec 24, 2008 | Harman Kardon Go + Play Portable Speaker...
LOGICTECH X-530
That speaker equipment should've came with an adapter to audio cables
its a rectangle that has 3 ports (orange,black,green) that lead out to 2 ports (red,white) from there u need the audio cables or AV cables
connected the red/white prong to the red/white ports on the adapter.
then connect the other end to the back of the tv where you will c white yellow and red
for dvd player connect it to the white and red ports
dont wry about the yellow 1 that is for video
Oct 18, 2008 | Logitech X-530 Computer Speakers
I just bought logitech speakers and when i plugged them into the computer they started working then as soon as i restarted my computer that stopped working now no speakers or ear phones are workingg when i...
Its most likely a settings problem or drivers missing maybe?
Hardly any need to buy a new port for speakers, unless its really broken.
try the speakers on another pc if they work fine there then its a problem in your pc, sound settings or drivers.
Check device manager
right click my computer select manage.
on the left side select device manager
note any yellow ! marks on sound devices or unknown devices.
Jul 14, 2008 | Computers & Internet
Logitech Z-2300 2.1 Computer Speaker System (3-Piece) Logo
Top Logitech Audio Players & Recorders Experts
Vernon Taylor
Lawrence Oravetz
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
