Hello Direct Code Entry Direct Code Entry lets you enter a code from the accompanying code list for your brand of device. It's not as easy as the other TIP: Each device key is associated with a type of device-the TV is preset to search for TVs, SAT•CBL•DTC for satellite receivers, cable boxes or digital TV converters, DVD for DVD players, and VCR•AUX for VCRs and DVRs. To program a device key for a different type of device, see the Changing a Key's Device Type section. The ON•OFF key serves as an indicator light during programming, giving you feedback at each stage of the 1. Manually turn on the device you 2. Find the Code List that came with the remote. Locate the section for the type of device you're trying to program, and find your brand in that section. Circle the codes for 3. Press and hold the device key you want to program (the ON•OFF key comes on). While you're holding down the device key, use your other hand enter the first five-digit code for your brand in the 4. When you've finished entering the five-digit code, keep holding down the device key and look at the ON•OFF key. Is the ON•OFF key on? YES: You're done! You've programmed this device key. NO, it blinked four times and turned off: You have either entered a code number that is not in the code lists or Remember to enter the code for future reference in the box provided in the Code Retrieval section of this manual. If your brand isn't listed in the code list, use one of the Code Search methods to program the remote control. (Refer to the Auto and Manual Code Search methods.) If you release the device key any time during the Direct Code Entry procedure, the ON•OFF key blinks four times, and the process is exited. The last programmed code under the device key is retained. Test the remote with the device to make sure the device key is programmed with the correct code for maximum functionality. If some features don't work, try a different code
Just buy one RCR 412BN, RCR 412SN or RCR 412SIN Universal remote control for your dynex tv.
Codes are
11463, 11810, 12184
methods, but it's potentially the fastest method.
process
want to control
your brand and keep them handy
code list (the ON•OFF key goes off after the first digit).
missed a step in the code entry procedure. Try step 3 again.
in the list.
OK.
SOURCE: need tv code number for 32"LCD Dynex Television for my universal
Ran a search and someone said Funai made it's codes are 0818, 0179, 0171
Someone else said it's made by Orion codes are 0236, 0179, 0463
You can try these codes hope they can help you.
SOURCE: NEED CODE FOR RCA UNIVERSAL REMOTE FOR DYNEX TV
This is the link http://remotefinder.rca.com/default.aspx?site=rca
You enter the model number of your remote control the product type and the brand. Dynex if it is not listed appears to be manufactured with parts from Toshiba and LG. There is a manual with all the remote codes at this link http://support.radioshack.com/support_video/doc66/66871.pdf but keep in mind that codes differ from remote control model number to model number. Hope this helps.
