SOURCE: Is our Canon T70 dead?
It sounds like the motor is locked up. The gears under the bottom of the camera may have gotten sluggish from dried out lubrication. You can take the bottom off to see if the gears are able to turn freely or check with a local camera repair shop.
CameraRepairs
SOURCE: Canon T90
It kind of depends on what exactly the problem is. If the problem is that the speeds are off, then that can likely be remedied without any new parts. It needs a clean, lube and adjust. If its due to the shutter curtains being worn and they need replacing, then there is a possibility that it uses the same curtain as another Canon model and parts can be had new for that model. Worse comes to worse, a parts body can be used for the repair.
Watch the cost of this stuff though. T90s on the used market are selling pretty cheap, so it might make more sense to buy another used and keep yours for parts.
SOURCE: Canon T90 Problems Loading Film
OK, the problem is that film door switch is faulty.
It needs alignment.
hi my name is John Lowe and I went on the training course for the T90 many years ago at Canon in London. I have literally repaired hundreds and have spares available. If you need info or a service dont hesitate to contact me by email at [email protected]
I am based in Staffordshire,England
Best Regards
John Lowe
