Question about Onkyo Audio Players & Recorders
I have purchase an onkyo HT-RC230 receiver. I want to connect a Directv R16-500 DVR & RCA L32W22 TV. Directv satelite service is currently connected to the DVR and DVR is connected composit S ports of TV. How should these be connected to the receiver?
Posted by american_pri on
Norman Skinner
  • 1,591 Answers
This is a rather uncomplicated satellite receiver, and basically only has a left/right audio out.
You can hook these into any of the stereo type inputs on the HT-RC230.
This receiver is also the "wal-mart" brand of Onkyo (not their best stuff) - so I suggest you take the L/R audio out on the DVR and put it into ANY available (cd/tape/dvd) stereo input on the receiver.
You aren't going to get better sound out of any specific input.
Posted on Feb 22, 2011
  • Eric
    Eric Dec 28, 2013
    yes! this worked for me. I have a starchoice shaw sat receiver and a onkyo 7.2 stereo receiver.
Need a service manual with schematic for a RCA Series 2 DTV 35 hour receiver (DVR40).
I don't think the service manual is available for these units since they have DirecTv built into them
Jul 26, 2011 | RCA DVR-40 DirecTV DTV Receiver / 35-Hours...
Onkyo HT-S6100. Receiver says NO SIGNAL and so
I have the same exact unit and same exact problem. Any luck yet?
Oct 16, 2009 | Onkyo Audio Players & Recorders
I have a Onkyo HT-S6100 sound system which has the HT-R667 receiver. I have a DirecTV dvr hooked up with hdmi, a PS4 hooked up with hdmi, and a Wii hooked up through component cables. The receiver is...
My HT-S6100 had a similar problem with my DVD player and some times with my Cable/DVR box. The signal wasn't getting received at the TV. So, first I changed the input jacks my DVD and Cable box are plugged into on the receiver (e.g. from HDMI 1 & HDMI 3 to HDMI 2 & HDMI 4). Second, I reprogrammed the Input Assignments to match (e.g. HDMI in 2&4). Third, I deleted any Input Assignments that weren't applicable. For instance, I'm only using HDMI connections, but there were Digital and Component Input Assignments programmed in. When I say I deleted them, I actually set them to "----" (just scroll through the options and you'll find this.) Finally, I turn on my video/audio sources (PS3 in your case) and let them load/warm up before I turn on my Onkyo receiver. It seems to be working. Good luck.
Sep 26, 2009 | Audio Players & Recorders
RCA DVR-40 Directv receiver will not make a call to Directv
i believe you have to slow the modem speed down. contact directv 800-531-5000 on instructions how to slow the modem speed. tell them you are getting "service not answering" hope this helps!
Mar 22, 2009 | RCA DVR-40 DirecTV DTV Receiver / 35-Hours...
Can hughes sd-dvr 80 be used as stand-alone dvr?
not without a subscription to Directv. after it enters the box it is basicly a Directv signal, it has to show up on the program guide.
Mar 10, 2009 | Hughes SD-DVR80 DirecTV / TiVo DTV...
No surround sound from my PS3 through the Onkyo 5100. Video OK
Unfortunately only the higher end Onkyo Reciever pass audio over HDMI for sound. 605,705,805,905 exc. Your reciever will carry Video over HDMI but you will need a digital optical cable for sound.
thanks.
Jan 24, 2009 | Onkyo Audio Players & Recorders
Remote Control Not Communicating with TX-DS787
Hello, I am sorry about your issue. Your hook up should have nothing to do with the remote. You should get some functions like on/off, volume control. Thank you, Onkyo, USA
Apr 25, 2017 | Onkyo TX-DS787 Receiver
Connecting a Dish 622 Receiver to the HTR500 and a Sony HDTV TV
I haven't researched to actual manuals for your equipment, but I'm guessing that the optical may be disabled when the HDMI is used. You could try using the component video outputs to the TV and then the optical to the Onkyo.
Jan 02, 2008 | Onkyo HTR500 Receiver
397 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
