Computers & Internet Logo
Posted on Feb 21, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My datatraveler 2g is write protected - Computers & Internet
Brian Sullivan
Level 3:
  • Computers & ... Master 27,725 Answers
  • Posted on Feb 21, 2011
Brian Sullivan
Level 3:
Answers
27725
Questions
Helped
5669969
Points
79191
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
# Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
also
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
hope this helps
don
WHAT IS WRITE PROTECT?
look on the side of the usb there is a little button that you push one way or the other to remove the write protect
2helpful
How to remove write protection from kingston usb drive
From the Kingston website:
DT101G2 - DataTraveler 101 G2 FAQ
Is there any security or write protection feature available for this DataTraveler? Unfortunately this unit does not have any security or write protection feature. If you receive a write protection message with this drive, check for the following:
  1. Verify that you are allowed to write to removable storage devices. There may be a security setting in the OS that disables write access to removable storage devices.
  2. Make sure you have not enabled write protection on the drive by using a third party software.
  3. If none of the above apply, the drive may be defective. Contact Kingston Technical Support for further assistance.
How to remove write protection from datatraveler 32gb
To remove write protection:
  • Open Start Menu >> Run, type regedit and press Enter, this will open the registry editor.
  • Navigate to the following path:
HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlStorageDevicePolicies
  • Double click the key WriteProtect in the right pane and set the value to 0
  • In the Data Value Box, press OK button
  • Exit Registry, restart your computer and then again re-connect your USB pen drive on your computer.
That is it, done. Goodluck
Write protect erroe give cant not format and copy files in my 8g DT101 data travel plz help me
write protect error give cannot format and copy files in my 4g DT101 data travel plz help me
Kingston datatraveler 512 MB is write protected. there is no switch.i cant format del data
Well u cannot do nothing than to kindly replace it. If u r able to get it working, it'll tell u same thing after sometime. 100%sure
Formating process of 2GB write-protected usb
Okay if you right click on the drive and open properties, you should see a check box that says Read Only. Make sure that that is unchecked. If it is already unchecked tell me and I will continue troubleshooting. Then attempt to format the drive again.
Ryan Frame
Creative Energy Associates Technical Center
REMOVE WRITE PROTECTED PENDRIVE
Should be a switch on the pendrive. Just push it in opposite side. That will disable the write protection.
6helpful
Grand Canyon Tech
Grand Canyon Tech
