I have a Polaroid PMP280cb-4 and the songs will only play for 10 seconds and then it switches to the next song. How do I get it to play the whole song?
Posted by tfinley2007 on
Anonymous
It's stuck on intro mode....I have the same Mp3 and I've had the same problem, just press the reset button on the side. (requires a pin or needle)
Posted on Apr 21, 2011
6helpful
Wont play the whole song
Sounds like the player is running in INTRO mode, only playing the first part of each song. To change playback mode, follow the steps as described below.
Switch the player ON and start music playback:
1. Press PLAY button to START music to play
2. Press PLAY button again to PAUSE the playback
3. Press MODE button to enter playback mode selection
4. Scroll with MODE button through selections
5. Press MODE button when selection REPEAT is in the display
6. Use MODE button to select from: Normal, Repeat One, Repeat
within current Folder (if any), Repeat Folders (if any), Repeat
All songs, Random Play back, and Intro
7. Press MODE button to confirm selection
10 second skip that wont stop.
you will have to go to your settings and change them. you have it set to just play intro now. you need to set it to play the whole song. hope this helps.
My E-Matic MP3 Player will only play songs for about 10 seconds, then it sequences to the next song for 10 seconds, etc. How can I get back to listening to a complete song?
make sure that when you imported the cd, that it did the whole song. My ipod does that sometimes too, but when i look back in my itunes, it just didnt import all the way. try re-importing the songs.
12helpful
My uncles mp3 only plays 10 seconds of a song each time it plays
Your Uncle's player is stuck in INTRO mode. To remedy this problem
1. Play a song
2. press the button on the side of the player
3. Select PLAY MODE
4. Choose NORMAL
Element MP3 player plays the intor of songs
Its most likely a problem with the song rather than the player.
Visual Land VL-507k series It plays 10 seconds of a song then skips to the next song
vl-507 mp3 play for 10 second of song then skip to next song
3helpful
2answers
ONLY PLAYS PART OF SONG
enter you menu and turn off review. Review plays 5 or 10 sec of every song on your player if its turned on. Trun it to normal and you should be ok....
Rate this solution if it helps.. Thank You...
2answers
Graig MP3 problem
will not connect to PC
10helpful
2answers
Won't stop skipping songs after 10 seconds!!
WAHA i've fixed it it was on repeat intro which means it plays the first quarter of he song so pretty much try to look at the repeat button and see if it is on that.....
1helpful
2answers
My MP3 player only plays the first 10seconds of a song.
maybe it's on intro mode, where it only plays the first ten seconds. enter the menu when a song's playing and change it to normal mode
Marvin
Marvin
