The manual can be downloaded at this web address. You just have to click on the stars on the four survey questions in order to keep them happy before you press the download button.
Hope it helps !
http://safemanuals.com/314159.php?k=3e3430682ded9424002b628db12ec341&ID=312433&q=CUISINART%20DCC-1200
Here is the manual:
http://www.cuisinart.com/share/pdf/manuals/dcc-1200.pdf
SOURCE: Self Cleaning feature
I copy pasted from the pdf..
Christian.
Self Cleaning:
If the Self Clean light begins to flash when
the coffeemaker is turned on, it is telling you
that the calcium buildup is interfering with the
functioning of your coffeemaker and the flavor
of your coffee. To clean, fill the water reservoir
to capacity with a mixture of 1/3 white vinegar
and 2/3 water. Press the Self Clean button.
When the self clean light glows, turn the
coffeemaker on by pressing the flip switch to
ON. The Self Clean light will shine steadily.
The coffeemaker is now in Self Clean mode.
One cycle should be sufficient to adequately
clean the coffeemaker. When the cycle is
completed and the five beeps sound, the coffeemaker
will shut off. Turn the coffeemaker
ON to see if the Self Clean light continues to
flash. If it does, turn it to OFF and then repeat
the cleaning procedure with a fresh solution of
vinegar and water.
If the Self Clean light no longer flashes, turn
the coffeemaker to OFF and then run one
cycle of fresh cold water through the unit
before using the unit again to brew coffee.
Notes on the Self Clean Function
Pressing the Self Clean button cancels all
other settings. If it is pressed accidentally,
press it again to return the coffeemaker to all
its previous settings. Pressing ON/OFF will
also exit the Self Clean Mode and turn the
coffeemaker OFF.
SOURCE: cuisinart coffe maker self clean
I found the manual here http://www.retrevo.com/s/Cuisinart-DCC-1200-Coffee-Makers-review-manual/id/890ci052/t/1-2/
Before you go working too hard to get
you oven to go into the self clean mode(self destruct)....check out
this tip...
Self
Cleaning Oven Problem
heatman101
Wish I had read this first. I never would have used the self cleaning
option. Thanks for the info!!
