I've got a problem with my dcrtrv14 (sony) handycam.
When loading it with a random tape it wil give error message c:31:23.
The manual says something about trying another tape or disconnecting the powersource or battery. I've tried this, so far not succesful.
Should I clean someting inside?
Thanks in advance for your answer.
Kind regards,
Gertie Vincent
If it were worth repairing, as a Sony agent, I would replace all of the capacitors and clean up the board then reset the mechanism and test.
Probably too old being 2001 vintage.
Here is Sony's page for the product: http://esupport.sony.com/US/p/model-home.pl?mdl=DCRTRV280&template_id=1®ion_id=1&tab=manuals#/manualsTab I don't see where it has support for any memory card format. If you can find any slots built into the machine, upload a picture and we could probably tell you what they are, but from what I've read, you're either using the digital 8 tape, or you're streaming over USB to a computer.
1. Turn off the Handycam
2. Remove the battery from the Handycam.
3. Remove the AC Power Adapter from the Handycam.
4. Move the Handycam power switch to the ON position.
Note: Leave the switch in the ON position for at least 15 seconds.
5. Move the Handycam power switch to the OFF position.
6. Connect the AC Power Adapter to the Handycam.
7. Turn on the Handycam.
Hi, The mechanical of tape loading compartment is misaligned and it needs readjustment which is a bit technical issue. Please contact any expert for mechanical adjustment of tape loading path assembly. This will solve your problem. Thanks.
I have a sony handycam DCR-HC26. After loading in the DV cassette tape and the tape cannot get loaded in and therefore I can't close the tape door. Please help.
Thanks
Hi, according to the symptom you don't need reset, This problem is related to the loading tape path which is mechanically unstable, that's why problem arise, For your convenience please see the given below pic of SELF DIAGNOSTIC SYSTEM to understand better.
Your camera needs just mechanical adjustment by any expert, contact any expert nearby or from Sony for mechanical adjustment, this will solv the problem. Thanks for using fixya.
