See me at website for images can only send one through this channel.
www.autorepairhelp.us
Best Regards,
Master Tech Lee
HEATER BOX SHIELD
Heater Box Heat Shield
Remove or Disconnect
1. Fasteners that retain heat shield to heater box assembly.
Image [ Heater Box Heat Shield
Install or Connect
1.Fasteners that retain heat shield to heater box assembly.
Tighten
-Bolts Screws to 2.2 N.m (25 lb in).
HEATER ASSEMBLY
Image ' Heater Hoses
Image ' A/C Evaporator Tube Assembly
Image ' Evaporator Core
Image ' Evaporator Core Assembly
Image ' Heater Assembly
1.Engine coolant. Refer to Draining and Filling Cooling System in Engine Cooling.
2.Heater hoses. Refer to Heater Hoses.
3.Instrument panel. Refer to Instrument Panel Replacement in Interior Trim.
4.Air inlet assembly. Refer to Air Inlet Assembly Replacement.
5.Vacuum lines.
Important
-Clearly label vacuum line connections.
6.Heater assembly studs inside engine bay.
7.Blower motor resistor. Refer to Blower Motor Resistor.
8.Stud inside heater core housing.
-Stud is revealed by removing the blower motor resistor.
9.Rear case screws.
10.Heater assembly.
11.Seals.
Imagt
Imagt
Imagt
Imagt
Imagt
Heater Hoses
Evaporator Core
Heater Assembly
Install or Connect
1.Seals.
2.Heater assembly.
3.Rear case screws.
4.Stud inside heater core housing.
Tighten
-Stud to 1.9 N.m (17 lb in).
5.Blower motor resistor. Refer to Blower Motor Resistor.
Tighten
-Studs to 1.9 N.m (17 lb in).
7.Vacuum lines.
8.Air inlet assembly. Refer to Air Inlet Assembly Replacement.
9.Instrument panel. Refer to Instrument Panel Replacement in Interior Trim.
10.Heater hoses. Refer to Heater Hoses.
11.Engine coolant. Refer to Draining and Filling Cooling System in Engine Cooling.
-Check the system for leaks.
Auto Repair Help US
