Curtis RCD-897 CD Shelf System Logo
Posted on Feb 21, 2011
How do I remove the needle/cartridge from the tone arm? And can I buy replacement speakers for the same model?
1helpful
2answers
I have a realistic clarinette 120 turntable . How do I replace the needle?
Most are held in place by 2 small screws, remove them and carefully unplug the cartridge from the tone arm, reverse to install new one, then check the balance the tone arm and set to correct pressure..
1helpful
I need a new needle- where can I get it- part number please.
Copy down the brand and model of the turntable and go to your local stereo shop. Radio Shack used to carry these, too - but I don't know if they do anymore. Sometimes the cartridge needs to be replaces as well. That will be the rectangular piece the needle is inserted to on the underside of the tone arm. If your see a name and number on it - write it down. The needle can be easy to replace - the cartridge however is a little more involved.
Turntable only playing in one speaker
In my business I work on a lot of turntables. Specifically, Memorex, Anders Nicholson, Innovative Technology and Emerson. 99% of the time when I only have sound coming out of one channel it is due to a broken cartridge. If you look at the tone arm head from underneath you will see a rubber fork that the needle arm sits in. There are usually 2 ceramic cartridges attached to the rubber fork. Those transmit the sounds from the needle. If one of those brakes then that channel will not transmit any sound.
Want to replace the needle on model #825 Fisher Price record player. Is there an easy way to raise the needle arm to view the cartridge slot or just slide new cartridge in from the front?
If you remove the lid off the player, the arm then swings all the way backwards and allows you ample viewing for needle replacement when turned upside down.
Oct 29, 2010 • Toys
1helpful
Can i purchase a needle for the ION ITTUSB ?
Yes but it is not the needle you would buy (ah in the old days it was a needle) but a cartridge
The user manual available here gives you a little more detail.
It is sometimes possible to get the needle assembly for the more expesive cartridges but yoy would need to know the cartridge make and model for that.
If you unscrew the headshell locking ring on the tone arm you can remove the cartridge by pulling it out (hold the arm and the headshell doing this)
This would give you a better idea of the cartridge make and model and also allow you to see how it is mounted (2 screws) to the headshell.
If this information was useful please click
1helpful
3answers
Plays records too fast, needle cartridge is loose
Many of these old phonographs play a little too fast. one possible fix is to rig up a dimmer switch into an "extension" cord that you plug this vintage phonograph into. The lower voltage will slow it down and you will be able to adjust the speed.
1helpful
Re:
Hi Vat,
Although I live in Canada now, I was born in the former
Czecholsovakia. While I spent a year in the Czech Republic in
2006, I was amazed how advanced their technology was, in
comparison to Canada or the US. If you want modern technology,
Prague is the place to go. Anyway ...
1) As I said before, do NOT adjust the tone-arm weight up
and down. This setting must be set to match the stylus and
the cartridge !!! The wrong setting is very bad.
To get the weight adjusted correctly, do the following.
a) Check the cartridge and stylus (needle) specifications, on
the WEB if necessary.
A typical tracking weight is between 0.9 grams to 1.5 grams,
but this very much depends on the needle geometry. To much
weight will damage the needle and the record, but
so will too little, because the needle will not stay on the
surface, skipping or mistracking on loud passages.
Note that the tracking acceleration is proportional to the
the square root of the loudness, multiplied by the frequency
squared. So if the tracking force is too low, the needle will
bounce over high frequencies and damage the record as
well as the needle's tip.
2) Once you know the correct force for your needle, adjust
the rear weight for ZERO force, such that the needle just
floats weightlessly in the air. If your turn-table has an anti-
skating adjustment, set that to zero as well.
3) At this point the tone-arm should be totally weightless,
and should neither touch the plater nor swing up/down
by itself. It should float halfway.
4) A this point, adjust the rear weight's dial (not the weight) to
read zero. Note that the dial will slide, while you hold the
weight still. You have now calibrated the tone-arm's zero
point.
5) Now, adjust the weight (with the dial) to read the desired
tracking force, for example 1.25 grams.
6) Now adjust the anti-skating dial to the same number as
the rear weight. This setting compensates for the radial
(towards the center) component of the friction vector,
caused by the needle riding on the record groove, at some
specific (average) tone-arm angle.
7) Your tone arm is now balanced, and you should not
touch it after this, accept for minor adjustments.
For brand new records, you may lighten the tone-arm
by 10%. For old records, you can make it a little heavier.
Similarly, you can adjust the anti-skating to prevent a
record from skipping, but a bad record should be played
only once (and stored on your computer).
8) For some tone-arms and cartridges, the cartridge pitch
(up/down angle) is also adjustable. This requires a special
jig or gauge, supplied by the cartridge manufacturer.
The pitch can be adjusted either by the use of screws or
wedges, and by lowering / raising the rear gimble. On my
Technics SL 1200, the gimble elevation is adjustable with
a large ring, and my SURE V15 cartridge came with a guage
for adjusting it correctly.
9) It may also be possible to adjust the cartridge's yaw and
radius, but all of these adjustments should only be done
using the correct gauges and by strictly following the
cartridge installation manual.
10) NONE of these adjustments should effect the tone-arm
cueing or return process. There should be plenty of
clearence if the cueing mechanism is working properly,
except, perhaps, for the gimble elevation, if the cartridge
is unusually tall.
11) Is the cuing mechanism (i.e. the tone-arm lifter)
mechanical or hydraulic ?
Is it the lift consistent or does the tone-arm drop down
with time?
Does the tone-arm move parallel to the plater, or does the
stylus height change with tone-arm position (yaw)
You are looking for a mechanical defect in the cuing
mechanism.
12) How much over all lift do you get between the down position
and the up position? This should be at least 8 to 15mm
If the cuing mechanism is worn out, it may not move enough.
If it starts too low, it may move enough but not raise the
needle enough to clear the record.
If the cartridge is tracking too low, you may have to
remove some wedges or spacers between the cartridge
and the head, or lift the rear gimble if it is adjustable, or
get a different tone-arm head, that matches the cartridge
profile.
Finally as silly as this sounds, make sure that the
platter is fully dropped and properly engaged. If the
plater is too high, for what ever reason, this would also
cause the needle to drag.
Also make sure that the rubber mat on the plater is the
right one and that it is not too thick.
Martin
2helpful
3answers
Emerson NR305TT - Replacement Turntable Needles
I have the same model. Though I haven't replaced the needle yet, I was able to remove the broken one. You'll see that the arm has a red plastic attachment. It houses the needle in a very thin strip of something like electrician's tape. There is a very small separation on the front (end of the arm facing you) of the tone arm, where the arm (black plastic) and needle "cartridge" (red plastic) come together. I used a metal nail file and pried them apart very gently. At this point the red plastic "cartridge" with the broken needle was hanging but still connected on either side. The red plastic "cartridge" is made with tiny plastic 'bumps' that pop into indentations built into the black plastic of the arm. Again, using my metal nail file, I simply held the arm and pried the red plastic "cartridge" away from one side. It popped off the other immediately and fell away from the arm. Voila!
Hope this helps!
Top Curtis Audio Players & Recorders Experts
SmartAviator
SmartAviator
Ngoro
john h
Are you a Curtis Audio Player and Recorder Expert? Answer questions, earn points and help others
