Question about Konica Minolta bizhub C351 All-In-One Laser Printer
I am trying to set the copier to black and white as default. I do not find in the manual where to change the settings.
Posted by cori812 on
just me
    New Friend:
  • 60 Answers
1. Select black on the main copy screen. 2. Select the Utilities/counter button. 3. Select [DETAILS]. 4. Select [2. USER SETTING]. 5. Select [3 Initial settings]. 6. Select [Current Settings]. 7. Return to the main screen.
ftp://207.18.56.26/software/BPG/UserbizhubC351CopyOperFW_G4.pdf
page 12-21
Posted on Feb 26, 2011
How do you change the default power up mode from color copy to black & white?
You will ahve to set up exactly the conditions you want for the default reset. Color option, quantity, manual or Auto exposure, etc. Then press the additional Functions key, then copy settings, press the down arrow key until Standard Settings is displayed, then depress it and then store key not initilize then OK ( YES ). This should get you in the general area of storing the settings you want.
Jun 17, 2011 | Canon imageRUNNER iR C2880 Color Copier
Is there a way for me to set my copier to default print black and white? I know this can be managed by each PC but sometime folks forget so i would like to deafult all print jobs to B/W unless otherwise...
TO SET THE MACHINE FOR BLACK AND WHITE ALLL YOU NEED TO DO IS SELECT BLACK ON THE COPIER PRESS THE UTILITY USER KEY THEN PRESS COPIER BUTTON DEFAULT BUTTON THEN SELECT CUREENT SETTING
THIS WILL DEFAULT THE MACHINE TO COPY IN BLACK TO SET PRINTING IN BLACK YOU CAN SET UP THE DRIVER TO PRINT IN BLACK ONLY
Jun 03, 2011 | Konica Minolta Bizhub 222 Black and White...
How to change to the default from colur to black and white on Bizhub series C35
Ok, it's been a while but here's what I remember. If your talking about default black and white COPYING, try the following. First set the machine to make B&W copies, then hit utility and go to user mode, touch current settings, then OK. B&W should now be the default.
Mar 14, 2011 | Minolta bizhub 350 Black and White Copier
Can the copy setting be defaulted to black and white document?
You can set it to B+W but it will revert to its default setting the next time you print.
Jun 30, 2009 | Lexmark X1150 All-In-One InkJet Printer
Copier will not operate
May want to check that default setting have been set for number and black and white, utilty then default settings reset to factory
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jun 22, 2009 | Minolta CF2001 Copier
Want to change the default to black & white not auto color
you set the settings the way you want on the copy screen ane then you store the settings under additional functions/common settings/store i believe
Mar 18, 2009 | Canon imageRUNNER C5180i Color Copier
HP Deskjet, Set to Black & White; but still prints with color!
Bronze, hopefully this is a logical issue: Assuming you're on WinXP > Go to Start>Control Panels>Printers (and faxes).
Find the printer in question in the list (maybe there's only one or 2 listed) and 'Right-click' on the icon > go down to "Printing Preferences" (about second/third down the list).
In here you will be able to set the printers default settings. I'm not 100% familiar with HPs printing dialog, but there maybe a setting there for either 'Black & White' and 'Grayscale' (albeit it should be greyscale, anyway...) if you choose black and white your printing will not have any mid-tone, so if there's a choise, choose 'Grayscale'.
You can set other features here which will become the new default each time you go to print something - personally I set to 'Draft' or 'Fast Draft' mode by default, that way when I just print out rubbish, I am saving "lots" of ink and if I want something in good quality, I change it at time of printing.
Now, there are some programs and files that "remember" you last print settings, so if you've used a colour print setting previously, that file may still pring in colour, even though the new defaults are mono (black & white). So, print using the new defaults and save the file when finished. It's unlikely the case with OpenOffice, but, I don't know. We'll tackle that as we get to it.
So, if that has not cured the problem, please let me know.
**.The best way to acknowledge contribution is to rate it's relevance.**
Feb 05, 2009 | HP Deskjet 3845 InkJet Printer
Reseting the default settings
set printer to black and white, press utility, user settings, save and select current settings then press set, should work
Sep 10, 2008 | Konica Minolta bizhub C450P Laser Printer
Can I set default printing to black and white for color laser printer?
Yes. Any printer's default options can be set as desired. Open the printer's properties (Start/Control Panel/Printers/right click the printer and left click Properties), and change the setting as you wish, then click OK. Those settings should be used each time you use the print command, unless you change the settings for that particular print job.
Hope this helps, and please rate my advice, good OR bad.
Feb 05, 2008 | Office Equipment & Supplies
Konica Minolta bizhub C351 All-In-One Laser Printer Logo
198 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
