Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Print slow pdf - Konica Minolta bizhub C250 All-In-One Laser Printer
Posted by rc2704 on
just me
    New Friend:
  • 60 Answers
Auto-hiding the DOCK through preferences will correct this printing deficiency but Adobe and Apple have not officially acknowledged this problem, even though it affects printing using any print driver.
Posted on Feb 25, 2011
Queue slow mfc 8860dn
Try to make first a PDF from your document (you can try 'save as' or 'export to' in the menu of your software application). Then try to print that pdf and see if it is printing still slow.
Nov 10, 2011 | Brother MFC-8860DN Printer
What can i do my canon ir3300 is printing a pdf file very slow
check the manual of the printer..if your printing a pdf form it is normal to print a pdf if you are printing more in color it depends on the image..observe the printing process of your printer.
Sep 16, 2011 | Canon imageRUNNER 3300 All-In-One Laser...
Acribat reader ir 3300 canon printer wery slowprint what is solution
Removing and reinstalling the printer driver will fix most issues such as this.
But if you are finding its just slow for PDF files read on.
If we break down the actual issue you will find that its not so much the actual printing part of the process that is slow, its actually the spooling/converting the document to the printer that takes the time.
Does your printer support PostScript printing ? (PostScript is a printing & imaging standard used by many printers) To find out if your printer does indeed support this either refer to your manufacturers documentation or perform a test page and look to see if you have a PostScript enabled option.
If your printer does support PostScript, make sure you are using its PostScript printer driver, most of the time we generally use PCL drivers, so simply change this.
Firstly we can force PDF files to be printed as graphics as opposed to text, to do this launch your chosen PDF viewer, select Print > Advanced > Print as image
This can also help to increase just about any slow PDF printing issues as it means that a soft font does not have to be created as the file is directly converted to a graphic and then printed as such.
Lower the print resolution (this can be changed from both the Windows print settings and from the printer itself if it has a LCD type panel) If we lower the print resolution most of the time the difference is very small, but it can reduce the actual file print size of the document by up to 300%, which can greatly decrease printing times, especially if your pc or printer does not have lots of memory (RAM)
Make sure you are using the very latest version of any print drivers or your chosen PDF printing program, normally Adobe Acrobat, as this will provide the most stable and efficient platform.
If the printer only has a small amount of memory if possible add more, if possible install a Post Script SI MM.
Feb 11, 2011 | Canon Ic2300N Printer
Printing VERY slow for PDF documents on DP-8045
well if you really needed a pdf printing concern, you may add an option which is Multi Page Description Language Controller Module. the post script printing language will be activated and you won't have to wait for the computer to process the pdf document on a gdi format (microsoft). what's more is that your mac computer can also directly print to the dp-8045.
that's it
Apr 30, 2010 | Panasonic DP-8045 Grayscale Copier
Slow printing out page
check driver, is it pcl or ps? always check for newest driver. PS always prints slower but has better end results
Aug 04, 2009 | Office Equipment & Supplies
Ir 3245 slow printing on pdf files
This may require a firmware update or even try printing the PDF file from a different version of Adobe.
Jun 25, 2009 | Canon Office Equipment & Supplies
HP Laserjet 1200 prints pdf documents slow
I had the same problem for printing pdf documents too slow with HP Laserjet 1200 :
Here's the fix: Open a pdf document go to File > Print> Advanced> check the box Print as image, use 300 DPI...that should do it.
CHEERS AND VISIT //dentaltourism.rs
Feb 18, 2009 | HP LaserJet 1220 Printer
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
283 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
