Question about Staples One Touch Executive Stapler
I can't find any instructions on how to reload my one-touch stapler. It shouldn't be hard to put instructions on the internet.
Posted by nroth872 on
Anonymous
    New Friend:
I'm new at FixYa, and I don't own this particular stapler, but I'll give this a shot.
Grip the black (middle) part of the stapler on its sides, flip it over (upside-down) and bend the base so you expose what would be the bottom of the black part of the stapler (now facing up, of course, because the stapler is upside-down). There should be a tab near the hinge that you can simply pull to expose the compartment where the staples are stored.
(That's how I reload my PaperPro stapler.)
Posted on Feb 28, 2011
I don't know how to load my stapler, I can't pull up the top to put staples in, like other staplers.........
Some have a small square piece on the tail end that must be manipulated and will some out for the reloading process.
If you will show the stapler to a bunch of people, I'm pretty sure someone will show you the drill.
God bless your efforts.
My stapler won't wrap staples around the paper. What can I do?
Amazon.com : The Classics Staple-Free Stapler the "Paper ...
www.amazon.com/The...Staple-Free.../B000IGCUZE
Amazon.com, Inc.The Classics Staple-Free Stapler the "Paper Grip" with 5 Sheet Capacity, Kid Safe (TPG-133). by The ... Gift-wrap available. Enter your ..... It is hard to get the correct pressure on the paper--too much and it tears, not enough and won't fasten.
PaperPro Prodigy One-Finger Desktop Stapler, 25 Sheet ...
www.amazon.com/PaperPro...Stapler/.../B000GGY9L...
Amazon.com, Inc.
Rating: 4.4 - ‎399 reviews
Gift-wrap available. ... One-Finger Stapling Technology only needs one finger to stapleup to 25 sheets ... The Paper Pro Prodigy Stapler is the most distinctive, powerful non-elictric stapler available. .... This is such a great, easy to use, and quality stapler that once you use it, you won't want to use a ... A near-great stapler.
Swingline® Full-Strip Stapler, 15 Sheet Capacity ... - Staples
www.staples.com > Office Supplies > Office Basics > Staplers
Staples Inc.Stapler can easily handle up to 15 sheets of paper at a time and has ... refill this Swingline stapler with a full strip of standard office staples, so it won't run out of ...
Staples One-Touch™ Plus Desktop Flat Stack Full Strip ...
How do I reload staplers?
There are two basic designs of staplers. The most common type is the Swingline or Stanley Bowstitch types. At the business end of the stapler there is a small catch that you need to pull rearward and the front staple head will drop down. Inside, you will see a metal bar and a spring. Pull the spring back towards the rear of the stapler and insert a full clip of staples appropriate for your stapler. Release the spring slowly so the metal tab pushes against the staples... should be pointed tips down. Put the stapler on a firm surface and press it as you would when stapling something. The two parts of the stapler head will join back together again.
How to load staples into rexel easy touch stapler
If you imagine that the end that the staples come out of is the front, then the back is where you load the staples. Your picture shows a small black bit at the very back of the stapler. You have to remove this, usually by pushing it in and lifting it up. Once loosened, it should pull out from the back of the stapler. You should then be able to reload. Finishing is the reverse process.
29helpful
User manual for one touch stapler H60
To fix the Staple's One Touch Stapler, you must pull the stapler open so it's at a straight angle. Then look at the picture on the bottom of the stapler. Its' saying to pull out the black click thing and then (here's the tricky part) put the staples into the body of the stapler, not the part you just pulled out. I always have to relearn that. My learning curve is getting slightly better, though.
What part do I need to remove to make a bostich MIIIFS floor stapler to shoot 2 inch staples
You shouldn't have to do anything to the MIIIFS flooring stapler to shoot 2" staples. It is designed to shoot 1 1/2" to 2" staples right out of the box. If your stapler won't feed 2" staples, check the magazine all the way up to the power head for any foreign material that may hold up your staples.
1helpful
I have tried to reload the stapler but it will NOT staple What am I doing wrong?
1. Make sure you have the correct staples for the machine. This machine requires "standard" staples, which are 1/4" staples.
2. Check the staple cartridge to make sure there are no visible jams.
3. Check the power connection to the stapler. Is it plugged in? Is the plug working?
4. If you continue to experience problems, contact the manufacturer at
1-800-STAPLES. They will replace the stapler if it continues to malfunction.
4helpful
3answers
I can't seem to reload staples into this stapler. I used the staples that came with it and it worked fine. I try reloading and it doesn't staple.
With the stapler sitting a solid surface, turn it 180 degrees so it is pointed away from you, and you are looking at the back. Press down on the plastic extension that you see (about mid-height on the stapler). This releases the staple-holding compartment (it shoots out the front of the stapler). Reload it with standard staples, push the compartment back in place until you hear a click. Voila!
6helpful
2answers
The spring came off of my one touch stapler. How do i put it back on?
Thanks a lot, michelle!
With your explanation I fixed my One Touch stapler. Just to help next people in distress, I'm posting a few images of te0c08250-e0c5-4c44-bc58-23feead87917.jpge7a403c5-d354-43a3-8988-e72c316a35d3.jpg8c88b735-483c-483b-830f-792d944bc24a.jpg8f1cbd61-1e15-4d8f-ad9a-87688667b68f.jpg6bc2a13e-46cd-4fe6-b8f7-d86468956057.jpg670dd768-1c0f-4f01-8c70-8f99ac34540f.jpghe fixing process.
9helpful
2answers
WHERE do I open it to refill it??
Located on the end opposite of where the staples come out, there is a spring loaded cap. Push it in toward the base of the stapler and slightly down to release the retaining hook. then let the spring release the pressure rod and pull it out. Connedted to the end of the rod you will see a plunger that is shaped like a short run of staples. Make a mental note of how and where this plunger slides into the base of the stapler. Place a run of staples into the stapler in the same manner that the plunger fits then replace the plunger into the same place following the run of staples. Compress the spring into the stapler and attach the hook as it was. Now you are ready to work.
NOTE: If you cannot compress the spring enough into the stapler you have inserted too many staples, just remove some of the run of staples and try again.
Staples One Touch Executive Stapler Logo
Top Staples Office Equipment & Supplies Experts
Vernon Taylor
john h
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
