Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
Posted on Feb 21, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to replace the belt. Have the belt and the vacuum bottom off. What do I attach the belt too?
Anonymous
Level 2:
  • Expert 240 Answers
  • Posted on Feb 21, 2011
Anonymous
Expert
Level 2:
Answers
240
Questions
0
Helped
69615
Points
512
This unit has 2 belts. The V-belt on the brush usually doesn't cause problems. The larger flat belt requires regular replacement ( belt # 38528-035 ). The belt is first placed around the motor shaft toward the rear of the machine, and then around the large pulley. You must have strong fingers to stretch the belt over the drive pulley. Start the belt at the top of the pulley, and try to "roll " it around the pulley a little at a time, holding the belt firmly around the pulley as you go.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 22, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
470
Points
P, li { white-space: pre-wrap; }
How To Replace Hoover Windtunnel Belt Littleton Colorado
http://www.youtube.com/watch?v=Z7m2MxYdnaM
Can't get the roller to spin
i suggest taking hose off and declogging it by using a water hose to make sure its free of debris. Plus check your belt first take off bottom plate the you'll be able to tell if belt is broken which it sounds like it is.
if belt is good and hose is clear and still brush wont spin then your brush motor needs replacing. hope this helps.
Sebo felix belt is broken,taken screws from bottom of vacum but will not come apart
There are actually two belts on your Sebo, one that drives the brush, and the second that attaches to the pulley on one end, and the motor shaft on the other. I'm assuming that the belt you need to replace is probably the brush belt, or the belt that attaches to the brush gear on side, and the pulley on the other.
Here's what you'll need to do:
Step 1. Remove the vacuum bag housing so that you are only working with the power nozzle or the bottom portion of your Sebo, this will make it much easier to work with. Turn the vacuum upside down, and remove only the 5 screws that I have circled in red:
Step 2. After removing the screws on the bottom of the vacuum cleaner, separate the top housing from the lower agitator housing, sometimes it may take putting a flat head screw driver in between the white and grey colored housing and prying them apart.
Step 3. You now have full access to the belts on your machine. It's most likely the belt that wraps around the brush gear rather then the belt that's attached to the motor that's gone bad. I have never replaced the motor belt in 8 years of servicing Sebo vacuums. The easiest way to replace this belt is to loosen the pulley system that the belt wrap around. Unscrew the two screws that hold this pulley in place, and remove the brush drive belt from the pulley, and now you can unwrap it from the brush gear as well now with the extra slack in it. Now, if you've been using your Sebo in your home rather then using it commercially in a business, Sebo actually offers a lifetime belt warranty on their vacuum cleaners. The belt is supposed to last as long as the vacuum, and Sebo will actually cover this repair, both parts and labor as long as the machine is being used in a residential home environment..
3helpful
Howto change a belt
Remove the top or bottom cover of the power nozzle/base of the vacuum. The screws will be on either the top or bottom of the base. Remove these screws to gain access to the brushroll. Remove the brushroll and attach your belt then putting the belt around the brushroll and using the brushroll to stretch the belt into place. Replace the top and bottom cover.
Jan 10, 2012 • Vacuums
8helpful
How to change belt on sebo the big drivebelt
Step 3. You now have full access to the belts on your machine. It's most likely the belt that wraps around the brush gear rather then the belt that's attached to the motor that's gone bad. I have never replaced the motor belt in 8 years of servicing Sebo vacuums. The easiest way to replace this belt is to loosen the pulley system that the belt wrap around. Unscrew the two screws that hold this pulley in place, and remove the brush drive belt from the pulley, and now you can unwrap it from the brush gear as well now with the extra slack in it. Now, if you've been using your Sebo in your home rather then using it commercially in a business, Sebo actually offers a lifetime belt warranty on their vacuum cleaners. The belt is supposed to last as long as the vacuum, and Sebo will actually cover this repair, both parts and labor as long as the machine is being used in a residential home environment. (This is the policy of Sebo America, if you're in the UK please check Sebo UK"s policy).
If you have any further questions on how to replace the belt, please feel free to reply to this repair by leaving your question in the comment section, I'm always more then happy to answer any question you may have.
Thanks again,
Chris Jones
goVacuum.com
Can not attach top back to bottom
Water pump on vacuum? steam cleaner / carpet cleaner? You have gotten something out of alignment. Check seal and make sure to have everything else in place before trying to screw back together
1helpful
Replace belt on cartpet attachment (kenmore)
on the newer models remove 2 screws on the bottom of the powerhead,also you need to pry the cover of in the back and sides.
they slip over a little ledge and hook to hold in place
1helpful
2answers
Replace the belt
Once the bottom plate has been removed, the motor shaft is silver, but hard to see. hook the new belt on it first. then start rolling on the top of the large black pulley to install.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
1800 vacuum cleaner belt replacement
Generic problem for all Vacuums
How do you get into the belt to replace it?
Not knowing the brand name of the vacuum other than the 1800 vacuum cleaner belt replacement, normally the belt is located @ the bottom the vacuum attached to the brushroll and is held on by either screws, clips, or some even snap on – but mostly they use some type of screws to open the area to replace the belt, if needed contact the company website, include the brand name and the model number and request a schematic of the vacuum and that will give you an exploded view of how the vacuum assm goes together and also shows the belt replacement and how that is connected.
http://www.dooyoo.co.uk/vacuum-cleaner/typhoon-1800-upright-vacuum-cleaner/1021772/
Apr 07, 2008 • Vacuums
4answers
Self Propel
Determine if the wheels spin freely or if there is resistance. Sounds like you need a replacement belt for the drive. If you need help with installation, let me know.
Top Hoover Vacuums Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
