My pc is at least a year old. Recently when I turn it on, the screen comes up with a series of vertical lines. After several repetitions of "on and off," the screen will finally come up with a viewable desktop display.
"On and Off" includes using the on/off button as well as battery removal including waiting a few minutes.
What action should I take - repair shop or some at home remedy??
How to Tell If A Computer Monitor Is Going Bad
Computer monitors are designed to work properly for years.
Whether it's from a defective part or power surge, they go bad eventually, and you'll probably know it when it happens.
Look for vertical or horizontal lines across your monitor screen that shouldn't be there.
Time how long it takes for your computer monitor to come out of sleep mode. It shouldn't take more than 5 or 10 seconds for the screen to be fully operational when taken out of sleep mode or turned on after being turned off. If the screen is not operating as quickly as it should, it could be a sign it's getting old.
Read more : How to Tell If Computer Monitor Is Going Bad eHow
Is the vertical line always at one location ? (on the screen)
If so, it appears that the video card/driver (on your PC or laptop) may be causing the line to appear occasionally ... i.e. flaky ... and it will likely fail (completely) in due time. To confirm it's the video card, try using another monitor (long enough) to see if it happens.
[ The line may also be caused by "dead" pixel on the screen ... but this usually happens on randomly located pixels on the screen, not on one vertical line. But, it may also be a possibility ... in which case, using a different monitor may prove it one way or the other ]
YES YOU HAVE DRY JOINTS UNPLUG FROM POWER SUPPLY REMOVE THE BACK/ INSIDE YOU SHOULD SEE AT THE BOTTOM SEVERAL RIBENED CONECTORS FROM THE SCREEN ITSELF? UNDERNEATH YOU SHOULD BE ABLE TO SEE 2 OR 4 COMPONENTS CAREFULLY APPLY A HOT SOLDERING IRON AN SOLDER THE ONE THAT YOU ARE HAVEING PROBLEMS YOU SHOULD NOW HAVE FULL PICKTURE AGAINE ANY PROBS email me [email protected]
We also have vertical lines with our JVC 62"... turning it off and letting it cool down is the only solution. For us, we know it's a problem with heat. We simply are wits end on fixing it. added two additional fans, a exterior fan to blow heat away from the back of the tv, pulled everything else away, etc.... Anyway, goodluck.
