EOP connections can see interruptions when the power line itself has noise on it. Air conditioning motors, hair dryers, fans...basically anything that can create "noise" on a power line can cause interference to ethernet over power lines. The first thing to do is see what may be causing the intermittent nature of the internet cutting on and off. We moved to EOP over a year ago and experienced the same problem in two rooms of our house. In both cases we found that the upstairs Air conditioner unit, when it was on, was throwing so much noise on the power line that it was interrupting the signal and our wall units would stop "chatting". When the unit cycled down, everything would work fine again. We had an electrician come out and install EMC noise filters to that took care of the problem with the air conditioners adding this noise and we've been trouble free save for the use of a hair dryer now and then.
SOURCE: Powerline ethernet lost connection
this is usually caused by dirty power, have you installed cfl light bulbs recently?
you might also check to see if any existing full fluorescent lights produce a buzzing noise.
SOURCE: My router won't link up to my modem. I have a
make sure that you ethernet adapter is enabled. you should be seeing a two computer icon in the notification area. reinstall driver of your eternet adapter.
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
SOURCE: Can you explain to an idiot, which exactly what is
Plug the PowerLine adapter into the wall
Plug one end of the ethernet cable into PowerLine wall adapter
Plug the other end of the ethernet cable into the Orange LiveBox
Plug the Orange LiveBox power adapter into the wall
SOURCE: Hi, I'm having issues with my current set up
Reset the powerline and Try with a different network ID. Try with a secure and unsecured powerline network to see if it works that way
