Question about Pioneer HTD-510 System
XV HTD510 system keeps blowing internal fuse .
Posted by jjameson9696 on
Keith Brown
  • 604 Answers
Fuzes blow because something is overloading the equpment. First make sure you speaker wires are not shorted, or touching each other. If the speakers are not shorted out, unhook them completely and replace the fuze. turn on the equipment. if the fuze again blows (make sure its the same value fuze and not a higer rating) then you most likely have a shorted output transistor or transistors. In this case you will most likely need to take the device to an electronics service place, or if its under warranty send to the manufacture. Most often these devices cost more to fix than to replace, so its your call on that. If your handy with electronics, you could try and get the schemetic for the device and try to fix it yourself. If you have a shorted "final" or "output transistors" you most likely also have burned out driver transistors and also some resistors. It's unfortunate that today most things are "throw away". one more thing, if the device has a strong smell, then the chances are good that something burned out
Posted on Feb 21, 2011
Electrovoice p1200 schematic
does it still blow fuses with no speakers connected ? is it blowing fuses for both channels ?
Jun 27, 2014 | LG Audio Players & Recorders
Marantz PM4001
The converter should not b e a problem. It's time to ask a technician or a HiFi shop, an internal short circuit is blowing the fuse. Don't insist.
Feb 05, 2014 | Marantz Audio Players & Recorders
Virago XV 250 headlight keeps blowing
The obvious cause would be a bad voltage regulator. If you search google there are some pretty easy ways to test that. I have the same motorcycle that had the same issue and the regulator tested fine. I noticed that the entire wiring harness was getting hot as well. It ended up being a jumper that someone had put in place of a fuse. The jumper wasn't letting enough current travel through the electrical system. I removed the jumper and installed a fuse. Problem solved.
Nov 01, 2012 | Yamaha Virago 250 Motorcycles
My 1987 Camry Alt Fuse Keeps Blowing. Brand New Alternator Brand New Battery . As Soon As I Change The 80 amp Fusible Link And Reconnect The Battery It Blows Immediately
I suggest to check if you have oil leaking onto your alternator or did you recently replace the alternator? Keep in mind that the voltage regulator is built into the alternator on vehicles and I have seen oil leaks internally short the alternator or poor quality aftermarket parts.
Also check ground and wires broke or in short.
Oct 20, 2011 | 1987 Toyota Camry
Using a T1.6AL fuse it blows in my JVC XV-N316 DVD Player. I wonder if the fuse should be a 6A fuse and not 1.6A?
only replace a fuse with smaller rating never larger,if it keeps blowing out some componet is shorting
Jan 08, 2011 | Computers & Internet
The dvd player will not play, will not spin -
the internal motor has gome bad change it
Mar 30, 2010 | Audio Players & Recorders
AMPLIFIER KEEPS BLOWING INTERNAL FUSES
You got an overload or short somewhere.  You got to fix that problem before putting in new fuses or you will be blowing your money away along with the fuses.
Oct 25, 2009 | JVC Audio Players & Recorders
PT FAN ERR
There is a fan located inside the unit used to cool the output chip. I iwould take a look to see if it is full of dirt, or is not turning.
Oct 03, 2007 | Pioneer HTD-510 System
5 disc tray opens and then shuts
Your problem could be one of three differnt things. It could be that the open close switch on the front has a bit of resistance to it, sand when you press it the switch starts to conduct and then the machine thinks someone has pressed the open/close switch again, or there are a set of small switches inside the unit that the door makes contact with when it reaches the end of the travel lenth, that is binding or broken, or there is a problem with the switch or microprocessor circuitry that is affecting the open close command. The correct repair procedture would to be to get a service manual and trace out these devices that I have just described.
Oct 07, 2006 | Pioneer HTD-510 System
Pioneer HTD-510 System Logo
Top Pioneer Audio Players & Recorders Experts
Steve Sweetleaf
Steve Sweetleaf
Jax Planet
Jax Planet
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
