SOURCE: Problem on Riso GR1700
Sometimes it is a one way pully inside the drum that is slipping.This is a mission to repair.
If you want to try it let me know.
SOURCE: What does the error code E 01 stand for?risograph 4050
E 01 means the main engine was locked
SOURCE: Can you use Riso GR1700 drums in a GR2700 or
The masters and ink should work. Cannot remember if the drum does. Put in the duplicator it will either fit or it won't. It will not damage the machine unless you try to force it in. If compatible it will slide right in and the machine will recognize it when you close the front door.
