2002 Ford Escape Logo
Posted on Jul 27, 2008
There is a CD jammed in the cd player. (6 cd changer) It is a 2004 Ford Escape
  • Anonymous Mar 31, 2014
    on the dash there are controls for a cd changer, how would I add a changer to the system.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 22, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
1552
Points
It happens to me all the time on my 2002. Try cycling the load and unload buttons for the stuck CD location. If that doesn't work try ejecting the CD. When the slot door opens, try putting another CD into the slot and push on the edge of the stuck CD.
3helpful
6 disc cd changer jammed in 2004 mercury mountaineer, says error when i try to eject or play jammed discs.
personally I used another not so valuable CD to push the jammed CD back, it appears the ejected CD may bump the open exit gate and get stalled. It has happened several times. Good luck
12helpful
5answers
6 disk CD changer in 2004 Chevy Suburban
I am having the same problem with my CD changer in a 2004 Suburban. Have you found a solution yet? Chevy dealership told me that I would have to replace the radio.
1helpful
2008 Ford Escape CD player keeps saying Initializing/CD Error
Have you tried lots of different CD's?? If so and still same I suspect CD player faulty.
14helpful
Jammed cd player - 2002 Honda Accord
I have a 2002 honda accord with the 6 disc cd changer. I beleve the cd changer has jamed and have lost power to the CD player. When I press the CD button it wont recognise the player. Any suggestions
1helpful
CD Player Problum
you can try pulling the fuses for the cd then replace them. as the cd is cycling on start up, hold the load and eject buttons, and then hit the unit, in hopes to release the jam.
11helpful
6 CD Changer/Radio on 2002 Ford Escape
Check this, it worked for me
http://www.i-hacked.com/content/view/213/45/
3helpful
3answers
STUCK CD
you will have to remove and open the changer, and remove cd that way, hope this helps
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
