You can often successfully recover deleted files from a PC, phone or camera memory card or USB Memory stick, it just depends on what's happened since the files were deleted.
When you delete files the data itself isn't deleted, just the index entry that says where the data for those files is located. The space containing the deleted files is also now marked as free space so it is available to the system for any new files to be written there instead.
If and when that happens, then it becomes too late to recover your deleted files so it is very, very important to not save any new files or data to the device concerned.
If the deleted files are on a memory card or USB memory stick, just don't save any new files to it.
One of the easiest ways to see if you can recover deleted files is to try some file recovery software. Recommended asoftech photo recovery as it saved my life many times.
http://www.asoftech.com/apr/
Photo Recovery should be tried in your case. Download the free trial version on your PC, then connect the device where your lost items located to start scanning. The program is also able to recover video and audio files. For Mac users, please go to Photo Recovery for Mac.
Remember - Do NOT try & write anything back until you can retrieve your files safely! I hope you good luck. Best regards.
What have you done to these downloading pictures?
Accidentally delete them or format them?
No matter what you've done to them, stop
use the storage device used to save them in case that any new file would
overwrite your pictures and make them gone forever.
And then, connect it to a computer and try
to restore all your pictures back easily
with the help of a photo data recovery freeware:
http://www.freeware-fix.blogspot.com/2013/02/photo-recovery.html
The deleted/lost photos are not actually
erased immediately as you think. They are still there and only become
invisible. That's why a data recovery program can help you out.
In fact, this photo data recovery freeware
has helped many people to restore their inaccessible and invisible data back
successfully. It would also work well on your storage device and get back all
your wanted pictures back completely.
Just give it a shot here:
http://blog4mark.blogspot.com/2012/12/photo-recovery-after-delete.html
Have you saved the pictures to digital camera's memory card? if so, you can use digital camera photo recovery software to help you get back the deleted photos.
Did you save the downloading pictures in the SD card of the camera,if so,that's easy, I recommend you have a try of Wondershare Data Recovery,you need a PC and connect your SD card, just a few clicks and everything is back.
