Question about Haier HVT12ABS Compact Wine Cooler
My wine cooler runs but doesn't cool. is it a fixable problem or do i just pitch it/
Posted by byron46 on
Wally Bald Guy
    Guru:
  • 683 Answers
Does the compressor run? let me know.
Posted on Feb 20, 2011
Whirlpool 22" wine refrigerator wwc287bls. Makes a high pitched sound pretty much constantly (compressor seems to run constantly too)
Howard, We're sorry to hear about your Wine Cooler making a high pitched noise. Our Wine Coolers are handled by a different department. Please call 800-263-2629 for assistance.
Jun 13, 2017 | Whirlpool Refrigerators
Why is it not cooling?
Your wine cooler problem could be caused by any number of things ranging from a bad thermistor (temp. sensor), loss of refrigerant in the compressor (leak), a failed thermocouple, bad circuit board, etc.. I would recommend having a reputable appliance repair shop look at it. Repair parts are available through Sears Parts Direct. If the repair shop estimate is over $300 - $400, you're probably better off just replacing it with a new one; unless you're particularly enamoured of this particular model for some reason. Good luck.
May 22, 2015 | Danby DWC283BLS Wine Cooler
Not colling
Check the back to see if the compressor is running or just really hot. If it is not running it could be a thermostat issue, but if it is hot and not running, that means your compressor has problems and will need to be replaced.
Apr 07, 2014 | Whirlpool 22" Dual Zone 38 Bottle Wine...
Wine cooler not cooling.
Your themostat inside the cooler may be broken.
Mar 19, 2014 | EdgeStar TWR282S Wine Cooler
Wine cooler doesn't cool
I recommend that you maybe add more details to your question so it will be easier for Experts to understand the question and answer it.
Oct 06, 2012 | Kalorik WCL-20629 18 Bottle Dual Zone Wine...
What is the best temperature for white wine to be in?
It is important to keep the wine cool and in stable temperature that doesn't fluctuate very often. Bright tart white wine: 48-52 degrees; sparkling wine: 50-55 degrees and rich white wines: 58-62 degrees.
May 29, 2012 | Furniture
It just stopt cooling ([email protected])
Turn the temperature dial to the lowest temperature setting. Wait 24 hours for the wine cooler to reach the desired temperature. Also, turn the wine cooler off and inspect the fan. If the fan if it's running or not.
Lastly, check the compressor.
These are the areas that could make your wine cooler stop cooling; the temperatue settings (Thermostat), then Fan and the compressor.
Check these three areas and let me have a feed back.
Bye for now.
Mar 04, 2011 | Haier BC112G Wine Cooler
Haier wine cooler won't cool
Does the unit cool at all? If it is running and not cooling properly, check and clean the condenser coils on the back of the cooler.
Jan 25, 2011 | Haier BC112G Wine Cooler
My cooler cannot cool
pull it out and lay hands on the compressor and see if its running if not replace the thermostat
May 27, 2008 | Avanti EWC28 Wine Cooler
Wine cooler doesn't cool properly
Few things to check here. If the compressor is not running then the problem may be a bad thermostat or the compressor start device (ptc starter). Most common would be the thermostat on wine coolers. Also need to check if the fan is running. If everything is running then you have a sealed system problem. If the fan is the only thing that is not running that will cause a no cool situation.
Oct 07, 2007 | Marvel 61WC Wine Cooler
Haier HVT12ABS Compact Wine Cooler Logo
209 people viewed this question
Top Haier Refrigerators Experts
Vernon Taylor
John Tripp
John Tripp
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
