Question about Dirt Devil Vacuums
I have a dirt devil upright vision and when I am sweeping it will shut off like it had overheated or something. I will unplug it and let it sit for a few minutes and it will start back up and then after a few minutes shut back off.
Posted by cassidy868 on
Chris Nomland
    New Friend:
  • 124 Answers
Hi Cassidy. You are probably right about the motor overheating. The usual cause for overheating is a clog some where on the bottom of the machine. Check for anything that could be blocking the dirt fro going into the bag. Hope this helps Chris
Posted on Feb 22, 2011
Dust Devil UD40180 repair manuel
Mate I just googled Dust Devil UD40180 repair manual and found this link, I hope it helps... If not then you google Dust Devil UD40180 repair manual It might give you some ideas...CHEERS
http://www.ereplacementparts.com/dirt-devil-ud40180-ultra-vision-turbo-bagless-upright-vacuum-parts-c-36976_37103_37186.html
Mar 12, 2016 | Dirt Devil Ultra Vision Turbo Bagless...
Where is the belt on the dirt devil vision turbo cant find it
the belt is to the left of the brush. You need to revome the plastic covering (4 screws) to see it.
Oct 27, 2009 | Dirt Devil Vision Turbo W/Bonus Upright...
How do I repalce the belt on Dirt Devil Swivel Glide upright vac?
Four screws hold the bottom plate in place. Turn the vac upside down and remove the screws that hold the cover(bottom plate) over the brush roll in place. Remove the plate and you are there.
Oct 22, 2009 | Dirt Devil M088910 Swivel Glide Vision...
Shuts off after a couple minutes of use
Sounds like it is stopped up. The vac gets overheated and the thermal switch does its job. Check suction from the hose and see what you get. If good then check the brush housing for a clog.
Aug 17, 2009 | Dirt Devil M086700 Vision Bagless Upright...
HOW DO YOU CHANGE THE BELT ON A DIRT DEVIL VISION VACUUM CLEANER?
With the vacuum unplugged, turn the machine beater bar side up. Locate the clips or screws that hold the plate over the beater bar and remove the plate. The beater bar sits in sockets just inside. Be careful in removing it; take your time and note how it comes out...this will make reassembly easier. Clean the debris while you have tha bar off and remove any debris thet you see in the vacuum hose area behind the bar....The new belt slips over the motor shaft behind the beater bar (further up in the cavity behind the b/b), then you slip it back onto the beater bar as you place the bar back nto the sockets. Test your work by revolving the bar a bit to make sure that everything is back in place. Replace the plate.
Regards,
--W/D--
Jul 12, 2009 | Dirt Devil M088910 Swivel Glide Vision...
Roller on my dirt devil vision not spinning
how do you replace a belt no.5 on a dirt devil vision.
Jan 31, 2009 | Dirt Devil Vision Turbo W/Bonus Upright...
Dirt Devil Vision bagless not working
Check the dirt cup filter. remove the dirt cup and check for proper suction. if you have good suction, check your belt
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Jan 24, 2009 | Dirt Devil Featherlight Bagless Upright...
Dirt devil en vision
download manual here
http://www.dirtdevil.com/CustomerService/Manuals/
Jun 15, 2008 | Dirt Devil CE5500 Floor Keeper Upright...
Dirt Devil M084600 Dynamite
If it is only 2 months old, then it is under warranty, take it in for warranty repair. There may be a circuit breaker on it, usually on the back at the bottom, it there is, push it to see if it has tripped.
Feb 25, 2008 | Dirt Devil M084600 Dynamite Bagless...
Vacuums Logo
1,050 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
Tim Venetis
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
