This happened to me 2 weeks ago. I searched this site and saw no responses, so I want to answer now that I know what to do. Pull out, clean and dry the spill assembly the cup sits on. Dry the open area. Let it set for about a week or two. I live in CA (its very dry here). I was so happily surprised when I tried my Keurig again yesterday - it is working like NEW. I used to work for another small appliance maker so I knew that the sensor had become wet when the spill assembly filled to capacity. Hope you still have your Keurig and this solution works for you too!
Like Sheritoga said, the sensor assembly probably got wet. Our cup sensor was blinking with or without a cup. I took the metal bottom plate off (just the 8 screws around the outside!) and left it open on it's side over night. You can see a black and red wire running to the front of the machine on each side from the circuit board. I used a hair dryer on COLD setting for about 2 minutes on each side and tested it prior to closing it back up. Worked like a charm for me! Good luck...
SOURCE: Our Keurig doesn't fill the cup. It generally
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
that will give you some things to try that will help you get your
Keurig coffee brewer working again.
Keurig
Coffee Brewer not making a full cup of Coffee
heatman101
i HAVE THE SAME PROBLEM WHEN i SET THE CUP DOWN THE GREEN SENSOR JUST KEEPS BLINKING SO i CAN MOVE FORWARD WITH THE BREWING PROCESS
'so I can't move forward with the brewing process '
