Question about Dell DJ Ditty MP3 Player
Hi!! I have n Dell DJ Ditty version A04 but i don't ave the cd software, wen i try to download from ere: http://support.dell.com/ (it's the only place where I found the possiblity to download it) but when i open it, it says: there is no file to open, try again later or something like this i try several time in differents ways but nothing change, do you know where can i get the software?? thank youuuuuuuuuuuuuuuuu
Posted by jupaltrinier on
John Porter
    Scholar:
  • 96 Answers
Hi...download an app called driver booster 4 from here http://www.iobit.com/en/driver-booster.php and run it...it should install any and all drivers/software you need in your dell...should you need any help with this app just ask as it is very good! Thanks for your enquiry,
Posted on Jul 21, 2017
5 Related Answers
Anonymous
SOURCE: My dj ditty don't work
wow. same thing with me. see the head phone jack? to the right of that is a black rubber circle. peel that off and the cover comes off.its obvious that you have a loose part. screw it in or watev! btw...isnt the best mp3 player...
Posted on Jun 07, 2007
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
SOURCE: DJ ditty wont work
Connector bent = replace the player
Posted on Jun 13, 2008
rjnworbnhoj
  • 142 Answers
SOURCE: Dell DJ Ditty
This is a flash memory type player, all you should have to do is plug it in to your computer, select the drive that it is plugged into and it should show all the items on that memory, then select all, and right click to delete. From here you should be able to select different songs from your files and copy them over to that particular drive... See if that helps
Posted on Sep 20, 2008
Anonymous
SOURCE: Dell DJ Ditty froze
I waited for the Dell DJ Ditty to run out of power then a charged it again and it worked!
Posted on Nov 19, 2008
jairo sanchez
  • 276 Answers
SOURCE: need installation cd for dell dj ditty
buscalo en internet solo ingresando el modelo
Posted on Aug 28, 2009
Need installation cd for dell dj ditty
Files on Dj Ditty won't show up on computer..
Sounds like you need to reformat the player, but here is my Dell Ditty troubleshooter:
Dell DJ Ditty
http://support.dell.com/support/edocs/systems/P97347/om/OM.pdf - manual
http://www.dellcommunity.com/supportforums/board/message?board.id=dce_djmusic&thread.id=47830 – How to Troubleshoot the Dell DJ Ditty – from Dell
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=PDA_MP3_DJ_DITTY&os=WW1&osl=en&catid=&impid= - Firmware for Ditty
Did you run the installation CD first? If you don't, Windows will load its own, possibly wrong, drivers.
Make sure you didn't accidentally press the player's lock button:
The keys on the Dell DJ Ditty have been locked.
Unlock the keys by pressing in on and holding the
Volume/Scroll/Select dial until the lock icon disappears.
Reset method - Insert the end of a thin object, such as a straightened paper clip, into the reset button (near the headphone jack).
Also make sure your operating system is Windows XP - it won't work on anything before or after.
The Musicmatch service that this player was tied to was discontinued in October 2007, so you’re going to have problems even if we get it working again.
The DJ Ditty does recognize DRM-encryption for WMA files – make sure the license is up to date, or convert the file to mp3 format if you are experiencing licensing issues.
If you are experiencing frequent freezing, or a file system/corruption error, or getting the “Warning! Reformat with Firmware Updater!” message, there are two ways to format the DJ Ditty:
Format using Windows Media Player:
Run Microsoft Windows Media Player.
Connect the DJ Ditty to the computer.
Click the Sync button on the top of the menu.
Click the "Format storage media" button on the right-hand side of the screen.
Disconnect the DJ Ditty and power it back on.
Reload or upgrade the Firmware:
Download and install the latest firmware from http://support.dell.com
Run the firmware upgrade program with the "Format Data Area" checked.
-Tha Mp3 Doctor
Dell DJ Ditty froze
4helpful
My dell dj ditty has frozen
Dell DJ Ditty
-Tha Mp3 Doctor
My dell dj ditty wont turn on
Dell DJ Ditty
-Tha Mp3 Doctor
Dell DJ Ditty
We may be in luck - I actually found an owner's manual for this one. Did you run the installation CD first? If you don't, Windows will load it's own, possibly wrong, drivers.
The Musicmatch service that this player was tied to was discontinued in October 2007, so your going to have problems even if we get it working again. Use Windows Media Player 10 instead (downgrade if you have the current version 11 installed).
Let me know how everything turns out.
-Tha Mp3 Doctor
Dell DJ
Unfortunately, it looks like the only available software still is the firmware for the device:
Other useful links:
http://www.dellcommunity.com/supportforums/board/message?board.id=dce_djmusic&thread.id=47830 – How to Troubleshoot the Dell Dj Ditty – from Dell
File compression
Use Audible to get Audiobook files
Mp3 is the most compressed format - you can go with lower-quality bit and sampling rates - that will save space, but diminish your play quality
Dell DJ Ditty MP3 Player Logo
Top Dell Audio Players & Recorders Experts
Jean Sintulaire
Ekse
Mandeep  Singh
Mandeep Singh
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
