Hello, unfortunately we are not trained technicians and we cannot advise you how to repair the unit. We would always recommend resetting the appliance by removing the power for 2-3 minutes. If that does not correct the problem we would suggest having a certified technician properly diagnose the problem that you are experiencing. If you would like further assistance you can send your name, phone number, address, model/serial number and the date of which you purchased your appliance to [email protected]. Thank you.
SOURCE: No power from Whirlpool.
The problem was a defective switch. There are 3 switches on mine. 1 on the top door latch, and 2 on the bottom. one of the switches on the bottom connected the power and neutral together, unless it was activated at the same time as the other 2, causing the breaker to trip or the internal fuse to blow. When unhooking the wire going from this switch to the other switch, everything works great now. Though I still need to replace the switch.
And for Basic 1. Yes my microwave did have a fuse in it it's ceramic, I got a pack of them at Radio Shack 4 for 3$ 250V 20 Amp. There should be a wiring diagram inside the microwave, mine was inside a black bag, so it may be hard to see.
Mine was up top next to the fuse behind the Plastic Grill and then a small metal grill. Some are behind the control panel, to fix this remove the screw at the top and then slide the control panel up and it should unhinge.
SOURCE: No heat but everything else works
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven.
Most people don't, for this reason, replace the magnetron, they replace
the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the
magnetron is faulty and you need to take it apart, find the proper
electrical leads and test them with a volt meter. To do this you have
to remove it from its mounting and take it apart. It is a fairly
lengthy process however.
Benjamin
SOURCE: Microwave is 21 years old. It is above the range
Um, no. You can get a new microwave that is much, much more efficient for a fraction of the repair cost.
SOURCE: My microwave is 4 years old. It stopped heating
There is no "simple" replacement on a microwave oven. The unit is a relatively uncomplicated appliance but in the same breath, is an extremely dangerous appliance. Not only are the micro waves dangerous, the oven operates in the region of 6000 volts and has components in it which can give lethal shocks even with the unit unplugged.
