Hello there,
Have you tried doing a factory reset? Can you also please tell me the exact model of your camera?
First try with new batteries as power received will be less as the batteries gets older and so flashes might not be working well. Clean the metal contacts of the battery holder properly with dry cloth and then insert the new battery and check you are getting power to the camera.
If you still face the problem, then inner conductivity is lost between battery terminals and circuit board.
Another chance that there can be the problem with flash lamp. You need to take to service center to get it repaired.
Hope this helps.
Shane
I'm sorry that the flash on the Camera is not working. If the Forced flash setting is already enabled and the flash is still not working, then the issue may be due to another camera setting. Even if the Forced flash setting is enabled, the flash will still not work in the following circumstances:
- When shooting MPEG movies
- When shooting in the Twilight or Handheld Twilight mode
- If shooting with the Burst or Multi Burst mode
- Shooting with Sweep Panorama
- Shooting with the Fireworks or High Sensitivity mode.
- If an external flash is connected
Please make sure that the Camera is not in any of the above modes.
no flash on my canon a620. setting is on auto and still no flash;
did not work. will take to service center. thanks
