Cameras Logo
Posted on Jun 23, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have such a Polaroid. but I don't know when would be appropriate to use the different flash options. flash options as in- the turnable thing at the top of the Polaroid which have a very bright sun, less bright sun, a cloud and a picture of a house etc. could you explain in which situation should I use the sun or the house or cloud option? etc as in- very bright sun flash option is to be used during sunny?/dark? environment.. thanks.. reply asap?
Tony Parsons
Level 3:
  • Fuji Master 6,405 Answers
  • Posted on Jun 23, 2017
Tony Parsons
Fuji Master
Level 3:
Answers
6405
Questions
Helped
1650080
Points
20272
This will be explained in the manual. Briefly, if there is sufficient ambient light, then using the flash is not necessary.
5 Related Answers
Anonymous
  • 48 Answers
  • Posted on Nov 16, 2007
SOURCE: dark pictures from kodak cx7430
Is your camera set to auto mode? I'm not sure if the CX7430 has manual settings or not, but try making sure its on auto.
Its possible the lens or the CCD (the device responsible for actually taking the photo) is going bad.
This guy - Darntoothysam has a CCD assembly as a low cost fix, 15 dollars.
http://cgi.ebay.com/Kodak-CX7430-EasyShare-Camera-Parts-CCD_W0QQitemZ250111578019QQihZ015QQcategoryZ64352QQcmdZViewItem
Anonymous
  • 148 Answers
  • Posted on Dec 24, 2007
SOURCE: CANON Rebel RTI Outdoor pictures are dark
learning to use light metering correctly can have its challenge.
the manual will guide you on how to set up to read light from the subject. spot metering a dark area will cause general overexposure, or a washed out look. spot metering a bright area will cause a dark image. if you are on spot meter and shoot two people standing together against a bright lit background, your meter will see between them if they are centered, and read all that bright background, setting the camera to a less sensitive combination of aperture / shutter speed, resulting in a dark image. use field averaging meter setting and be sure you are metering the subject and not the background. try shooting a wall that is fairly clear of other colors and uniform it light hitting it, you should have a correctly exposed image. since it works in other modes (at least 1, anyway) then it is unlikely you have an exposure compensation issue. that is the only other non defect issue that would cause your problem.
once you confirm that you have these settings correct and still get a dark image, its time to have it serviced.
good luck
mark
Anonymous
  • Posted on Feb 25, 2009
SOURCE: screen problem
it is clearly a case of "you got ripped off" just like me
Anonymous
  • 41 Answers
  • Posted on Apr 24, 2009
SOURCE: Mitsu 65" DLP-picture seems washed out
Most likely cause of your trouble is dust on the small mirror inside you set. Your DLP set has 2 mirrors not including the DLP chip itself which has about 500,000 tiny mirrors. The 2 mirrors reflect the DLP chip image to the screen you view. The first is the main suspect it's about 4inches by 7inches. It's mounted on the bottom center facing backwards. This mirror faces slightly up and somtimes after time dust, smoke, dirt settles on it . The second fills the space of the entire back of the cabinet but it faces down and takes alot longer to get dirty.
The compartment is sealed but dust seems to find it's way in. If you remove the screws that secure the screen assembly from the top , sides and bottom. Make sure to have a friend available the screen assembly is delicate when it's not mounted to the cabinet. You can remove and clean the mirrors. These mirrors are glass and you can use glass cleaned. Don't use glass cleaner on the screen it's plastic. You can clean it if necessary with plastic cleaner only. Probably not needed.
Good luck.
bhargav
  • 66 Answers
  • Posted on Mar 04, 2010
SOURCE: My pictures are too dark
This cheap flash work normally if ISO is set to 400.
But put it aside and I bought Nissin 622di and it works great in all modes
1helpful
The "Clear searches" option does not work on my tablet, it worked fine yesterday..how can I fix this?
Settings ' Developer options ' uncheck "Don't keep activities" or install a different Internet browser.
1helpful
With what can i cover a polaroid flash
The Polaroid 600 doesn't have an automatic flash. To use the flash, insert the flash bar into the flash socket. To turn off the flash, remove the flash bar. Refer to the manual.
If you have a different camera, please reply to this post and give the model number.
Can you turn off the flash on the Polaroid i1237?
Press cursor-right repeatedly to cycle through the different flash modes. To turn the flash off, select the lightning bolt in a circle with a diagonal slash through it.
Full details are in the "Using Flash" section of the manual (page 29 in my copy) If you need a manual, you can download one at
http://store.polaroid.com/media/document/i1237_manual_EN20090730.pdf
The flash on my polaroid t831 is too bright. it
set auto white balance, or use a small paper in front of camera, seems like your camera is defective.
How to set smart sound on polaroid tv model # tda-03211c
As far as I am aware, only Philips Magnavox has this option.
I did some searching and have yet to find this option for your tv. I will do further searching and let you know if I find anything different.
1helpful
Using other Camera software with a Poloroid 640 Fun Flash
I have three different digital cameras. I use the scanner and camera wizard to download my pics.
The second option, if you use SD card with your camera, then you can get a USB 2.0 SD Memory Card Reader/Writer.
1helpful
Help with Polaroid 600 film choices & how to use One Step Cameras
the flash will work when you put film in. the film has a battery and the camera works off the battery in the film. the arrows make the picture dark or light.
the polaroid spectra onyx made in 1987 is a totally sharp and beautiful looking camera. you also can put filters on the front of it. this camera was used by law enforcement many years ago so it is made very steardy and well. i own one myself and the pictures are perfect everytime. look this camera up on Ebay, you will not be disappointed.
also, here is a website for you to look up film information
polaroids.theskeltons.org
this website will have everything you need and more
Jan 03, 2009 • Photography
1helpful
Flash detail
Use the right arrow button on the arrow pad. There is a little pic of a lighting bold beside a pic of a camera on the top left hand corner. Push the right arrow button and look at that lightning bolt you will see it changing. There are three different ones. One has a ling through it and that means no flash on had an "A" on it that stands for automatic and then you will see just a pic of the bolt without anything. Not to sure what means either. Hope this helps.
Top Fuji Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Fuji Camera Expert? Answer questions, earn points and help others
