Question about Mitsubishi WS-55857 55" Rear Projection Television
At times the screen becomes double - Mitsubishi WS-55857 55" Rear Projection Television
Gary Labadie
    Novelist:
  • 99 Answers
When you say "double" do you mean you see the colors somewhat seperated or see maybe blue or red outlines around objects? Does the screen distort?
If so then:
Your Convergence ICs are likely failing or it is a bad solder joint related to that area. It is very common on rear projections. The solution is to replace the STK chips, check fuses and the resistors next to the STK chips. Replace as necessary and re-align via the service menu. It is about a $300 repair at a tv service center. You will need the service manual if you decide to do this yourself.
Try This:
When you notice the symptons Use this simple test to verify.
Go to the users menu on the tv.
Look for the converge option probably under setup or video setting. Converge is short for convergence to align the red and blue colors to the green color.
If you cannot move the red either horizontal or vertical, then the STK chip has failed for red section.
If you cannot move the blue either horizontal or vertical, then the STK chip has failed for the blue section.
If you can move both in each direction then the problem is something else.
Note if one STK chip fails, you replace both regardless. There may only be one STK chip in this set. If there are two, they will be right next to each other.
Posted on Feb 20, 2011
My laptop start up but it shows double screen,somtimes just become blank?
try reinstalling your graphic card software... or maybe a hardware malfunction. try contacting a technician.. maybe your screen or thw ribbon is damaged..
Apr 15, 2016 | Prolink GeForce Computers & Internet
Double vision screen
This is most certainly a display problem, as in, a problem with the LCD panel. I used to fix 4 or 5 LCD's a day and had a few with the same problem. It can be fixed by being replaced.
Jan 06, 2014 | Computers & Internet
Screen getting bigger
try lowering the sensitivity of the screen.... (somwhere in settings)
Dec 10, 2013 | Cell Phones
Screen faded
the screen is dying, replace it.
Oct 07, 2013 | Acer Computers & Internet
My screen has a puple line accross and has a double figure with purple background.
these TV usually have something call magic focus. this sometimes will fix this problem. it might be located on the remote or on the from of the set. you might have to run it a few times. sometimes the lamps become unaligned and cause this problem...good luck
May 04, 2010 | Hitachi 53UWX10B 53" Rear Projection...
Every thing looks doubled
On board above your Chassis it has a regulator IC
STK730-010? replace it! Call Mats Electronics 1-800-628-1118
Jan 06, 2010 | RCA P52926 52" Rear Projection Television
The image of my 53sbx10b are double after few minute
Replace convergence ics. Hitachi has a ki for this consisting of STK-395-110 ic and some resistors.
Apr 13, 2009 | Hitachi 53UDX10B 53" Rear Projection...
White screen when playing pc games
Sounds like 1- you have a virus or 2- your computer's graphics card is not sufficient for the game you are trying to play. Double check all the requirements, if you meet them you have a virus. Hope i've shed some light on the problem :)
Mar 18, 2009 | Video Game Consoles & Games
Open Questions:
Mitsubishi WS-55857 55" Rear Projection Television Logo
88 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
