Sharp Lcc4067un LCD TV Logo
Posted on Feb 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a line on thr middle of the screen - Sharp Lcc4067un LCD TV
hims Patel
Level 2:
Scholar:
  • Expert 102 Answers
  • Posted on Feb 20, 2011
hims Patel
Expert
Level 2:
Scholar:
Answers
102
Questions
Helped
13482
Points
303
Line on the middle of the screen indicates that the liquid of that particular pixel is failed , so you have to change your screen or TV.
thank you for give me chance to help you,
please give your ratings!
Why do I keep getting a line in the miidle of pages when I copy ?
It might b toner prob. Plz check the toner if it has any small piece of paper or anything stuck into it. If u find anything thr, remove n try copying. N if thr is nothing thn u might hv to clean the toner and if the line is still thr thn u hv to replace the toner.
Blue light
You cannot. The blue blotch is a sign that your optical block is going out. This will only get worse. The optical block will need to be replaced. This is not cost effective.
Top, middle of screen there is a constant flicker. The flicker starts at the top, middle and goes about half way down the screen.
I have a blue line about 3/4 inch wide from the top right to the middle bottom. ( not a straight line ) I replced thr projection lamp with no fix to the problem. I added an additipnal fan and cleared up the problem. On furthe investigation I replaced the air filter and kept only the original fan and the problem was solved. Can you explain this.
Red doesnt line up screen looks like its fuzzy cant get thr red to line up on the squares
A bad correction IC or ICs are at fault here..See a tech soon..And try not to watch your tv too long as more damage is immenent!
1helpful
It starts but will not keep running.
if it starts and then dies it sounds like thr carburator there a little screen in the carburator the carb has two sides one plate has one screww in the middle and on the other side has 4 small screws open the one with the one screw you will see the under the plate
Red line on my laptop screen
This either could be a damaged screen which needs replacement or this could be the monitor cable comming disconnected from thr graphics card inside the laptop.
Takethe laptop screen away and reconnect the ribbon cable or replace the screen
MY CD DRIVE HARDWARE DISAPPEARED IN THE MIDDLE OF READING THR CD
Wow that is strange.. You might wanna go to your device manager by rigth click on my computer and enter properties once you open the device manager highlight my computer from the screen and click on the tab action and scan for the harware change it should recognise the Cd drive and reinstall it
1helpful
2answers
Sansui tv sv2918
replace vert IC301, C432, ( D431 & R431 should also be blown)
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
