Please connect the router directly to the computer with a network cable and switch on the router.
It will couple of minutes and your computer should have got a IP address from the router.
Go to command prompt :
1. Click on Start / Pearl / windows Orb
2. Click on Run (windows XP) / Search box (Vista / Windows 7)
3. Type Cmd and hit the enter key.
4. You will be in a black screen (command prompt)
Find the IP address of the router : Type the following
Ipconfig (and hit enter)
you will see the a number in this format - 192.168. X.X next to Default gateway.
Write down that number
Access Router page:
1. Open a browser window - Internet explorer / Mozilla
2. In the address bar type the default gateway address you noted down
3. Click on the Go button / just hit enter.
4. You should get a username & password request screen
Default ones are usually (unless any one has changed it or set differently by the manufacturer - refer the manual also)
Username: Admin or Administrator
Password: password / admin
In this screen you should be able to click on Wireless setting and there you can see your WEP key or you can change it to the one you wanted
Please click on the link below and choose the hardware version available in the sticker located at the bottom of the router. You can download the manual at this location and follow the steps. In case you need assistance please reply to this post
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
On your ipod touch
Verify Wi-Fi is enabled and that you are connected to a Wi-Fi network.
Tap Settings > Wi-Fi. If Wi-Fi is off, turn it on by tapping the on/off icon.
Available Wi-Fi networks appears under "Choose a Network..."
Locate and tap the Wi-Fi network you want to join then enter your password
Turn on your computer and locate the Wi-Fi icon. This is located in the system tray in the bottom-right corner of the screen. The icon looks like a series of rectangles that increase in size from left to right. Right-click the Wi-Fi icon and select "Connect to a network." You will see a list of available wireless networks. Choose a Wi-Fi network you want to connect to and select "Connect." Enter the password into the password text box if a password is required. If a password is not required, you will automatically connect to the Wi-Fi network. Click "OK."
