SOURCE: Cant sync wii balance board
I know it's been a while since you have posted and have prob already figured it out. But just in case this may help someone else. Try turning off your wii and unplugging from the power source for a few minutes. The plug back in and turn on. At the initial warning screen press and hold the sync button on the wii console for about 4 sec. You will have to resync your wii remotes. Next make sure the disc for the game you are going to use the balance board with is in the system and start the game. Then try to sync the balance board.
Put four AA batteries into the battery housing located on the underside of the Wii Balance Board.
Insert a Wii Balance Board compatible game into the Wii system.
Select the "Disc Channel" on the screen with the Wii remote, and choose "Start."
Open the SD card slot to reveal a sync button on the Wii system. This is located behind a cover under the power and eject buttons.
Turn the Wii Balance Board upside down.
Remove the battery cover under the balance board to reveal another sync button.
Pres the sync button on the balance board, then press the sync button on the Wii. Do not hold down the buttons. You know it is synchronized when the blue light on the Wii Balance Board stays steady
Place the board on a flat surface directly in front of the TV. Face the power button away from the TV.
