Computers & Internet Logo
Posted on Feb 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wanted to know the default or factory ip address of my siemens se568
Anonymous
Level 2:
Sniper:
  • Expert 96 Answers
  • Posted on Feb 20, 2011
Anonymous
Expert
Level 2:
Sniper:
Answers
96
Questions
0
Helped
44234
Points
354
Art Weaver
Level 2:
  • Expert 55 Answers
Art Weaver
Expert
Level 2:
Answers
55
Questions
Helped
17487
Points
146
It should be on the bottom on a label.
If not try 168.0.0.0 in a ping, that "might" get a response with the precise ip
if your lucky and the default gateway is set to 256.256.256.256 or 0.0.0.0
This probably "wont" work but it's worth a try!
There is also another way to get this but you will have to look up the UNIX command on the web,
It's either FIND or SEARCH that will give you ALL of the ip's connected to the PC originating it.
I have not used this in a LONG time so dont remember exactly....
GOOD LUCK!
Unable to reset Siemens SE568 router to factory settings. pressing button at base of unit reboots device but does not restore factory settings. need to access gateway to configure wireless network. How...
Reset button on the back of the router. You will probably need a toothpick to press it. Recommend holding it in for 30 seconds. Hope this helps.
1helpful
I have Dlink 615 model router. i reset one time and now i want to change again my name and password but i cant log into. I try admin in with the IP address and also my user name and password but i cant get...
When you reset your router the IP address will revert back to its factory default IP address and access information, if you changed the IP address prior to the reset you will have to use the default IP.
default IP: 192.168.0.1 (make sure that your network cards IP address is somthing similar like 192.168.0.2 and not 192.168.1.2)
Default username: admin
Default pass: leave blank
If you are still having issues let me know.
1helpful
By which ip using i can open the config page of
First connect the router to your PC, click Start menu button on taskbar click run type cmd now type ipconfig, see the Default Gateway address, open your browser, and type the same address...now the admin page will open....For further help please be with us.Thanks for using Fixya...
2helpful
2answers
I would like to know how to reset the Lexmark E260dn to factory defaults. The printer was set with a static IP address and no longer exists on THAT network. I need to set it up as a DHCP client again to...
Restoring the factory default settings
Do one of the following:
• If your printer is on a network, access the Embedded Web Server:
1 Type the printer IP address into the address field of your Web browser.
Note: If you do not know the IP address of the printer, print a network setup page and locate the IP address in the TCP/IP section.
2 From the Settings screen, click General Settings.
3 Under Factory Defaults, select Restore Now, and then click Submit.
• If your printer is connected to a computer by a USB or parallel cable, use the Local Printer Settings Utility for Windows or Printer Settings for Macintosh.
1 Open the utility.
2 Do one of the following:
– From the Local Printer Settings Utility menu bar, click Actions Restore Factory Defaults.
– From Printer Settings, click Factory Defaults.
Warning—Potential Damage: Restore Factory Defaults returns all printer settings to the factory default settings except Network/Port menu settings. All downloads stored in RAM are deleted. Downloads stored in flash memory or on a printer hard disk are not affected.
Or please download the user guide from this link and follow the instructions
http://static.tigerdirect.ca/pdf/Lexmark-E260D-Series-Mono-Laser-Printer-Manual.pdf
Hope this will help you
thanks
4helpful
2answers
How do I access my siemens se568 router? I have just connected it to my PC but nothing happens? I have a 3G Connetion on my Home PC using my Nokia Cellphone that I want to share with other devices in my...
hey try this
start>run>cmd>type ipconfig all
try to check what is the default gate way and then try to type the same thing on your browser .
you would be able to access the router page
3helpful
2answers
Ip address to access Siemens sb5830
Make sure you are on the same subnst as your router.
Go to:
http://192.168.254.254
login is superuser
password is admin.
How to assign IP address to HP procurve1800 switch?
The 1800 series do not have CLI so you should connect directly to any RJ-45 port.
I quote from the installation guide:
"In the factory default configuration, the default IP (Internet Protocol) address of the switch is 192.168.2.10 and the subnet mask is 255.255.255.0"
So set your PC IP address in the same subnet and access it through your web browser. If it has not the default configuration, interconnect the switch ports 1 and 2 and reboot it.
Hope this helps,
take care
AFO
1helpful
5answers
Gigaset se568 siemens wireless Security setting
i have a little problem with my siemens gigaset SE568, here all led lights are glowing except the internet, i checked my net connection with another modem and the result was positive but what is the problem here i can't figure out,please help me,rahat
I am having trouble accessing the ip address for this modem why?
jab follow the step below to access your DSL, the ip given is a default ip from the factory.
pls reset the DSL before you continue(press and hold for 4-6 seconds until the power button blinks red)
Connect a computer to the modem.
Turn on modem
Turn on computer
Use a browser to open http://192.168.0.1
Click on Advanced.
(you then have lots of things to look at)
Siemens Speedstream 2624
Find the reset button on the rear panel of the wireless device and follow the factory reset instructions below: 1. Power Off the router. 2. Hold the Reset Button down while you Power On the router. 3. Continue holding the Reset Button until the Status (Red) LED blinks TWICE. 4. Release the Reset Button. The factory default configuration has now been restored, and the Router is ready for use. The DSL/Cable Router's default IP Address is 192.168.254.254 To establish a connection from your PC to the DSL/Cable Router: 1. After installing the DSL/Cable Router in your LAN, start your PC. If your PC is already running, restart it. 2. Start your Web browser. 3. In the Address box, enter "HTTP://" and the IP Address of the DSL/Cable Router, as in this example, which uses the DSL/Cable Router's default IP Address: HTTP://192.168.254.254 The first time you connect to the DSL/Cable Router, the Setup Wizard will run automatically. (The Setup Wizard will also run if the Router's default settings are restored.) This should get you in the right direction. ZT3000 "Beta tester of "0"s and "1's"
Grand Canyon Tech
Grand Canyon Tech
