Question about Lenovo ThinkPad X100e (350829U) PC Notebook
My computer just got a new hard drive, and now has internet problems. The connection to the internet stops frequently, and doesn't restart until i got to the internet adapter page and reset the wireless adapter. All the other computers in the house don't have this problem, so most likely it's the computer's problem.
Posted by joshuazhu on
Joseph Wright
  • Lenovo Master
  • 1,645 Answers
If the computer goes into sleep mode, some devices won't wake afterwards. As a test, either disable sleep mode, or open Device Manager, find the adapter or its USB port and set the power properties to not allow the device to turn off to save power.
Posted on Dec 12, 2017
4 Related Answers
anandg27
Anand Gupta
  • 1272 Answers
SOURCE: Wireless connection works but internet page does not open
Diable firewalls on the computer and check if that helps. Also, reset the Explorer to default settings. If the issue persists then please install another browser and check if that helps.
Please Rate, if it helps.
Posted on Jun 22, 2009
Anonymous
SOURCE: Lenovo Ideapad Y450 - internet problems
Checkout the solution at:
Remove ReadyComm. see steps at:
http://www.amazon.com/Lenovo-IdeaPad-Y450-Recordable-Accelerator/dp/B0029Y1L2Q
My driver did not uninstall cleanly. I had to restart and do the uninstall again. And then the next reboot, the wireless driver got added automatically.
I tried this, but that didnt fix it all
Sometimes the wireless switch is off (Fn+F5) when you reboot the system (not the physical one).
Some people have suggested that you need to disable WEP encryption. Thats not necessary.
Mine works fine now, but it is frustrating (I have DSL and had issues connecting to the router too. try gateway.2wire.net). if that doesnt work try gateway.2wire.net/setup
Posted on Jul 08, 2009
mpcheeseman1
mpcheesman1
  • 1400 Answers
SOURCE: Lenovo G550 running Windows 7 won't connect to
Hello
Wow youve done almost everything here.How about the firewall? is it blocking any connections?
Next,Go to control panel,network and sharing center.Look and see if the pc or laptop in question is on the same network,meaning home or public.
Set all your machines to the same network.Either home or public.I do know this has been a win 7 problem.
Posted on Mar 11, 2011
SOURCE: Blue screen error plus blank start up screens but the start up sound can be heard.
Have you changed any BIOS settings? I would open your BIOS menu and make sure it is set to "AHCI"
Posted on Aug 21, 2012
Doesn't recognice drive
In my limited experience such things are caused by software conflicts where substandard software replaces parts of the operating system or approved programmes with other versions. The displaced software might be lost or deleted but the operating system tries to repair things and fails.
Nero burning software seems particularly bad, working fine when first loaded but deteriorating after every restart until finally it stops working altogether but deleting it doesn't fully restore previous functionality.
Nov 12, 2017 | LG SuperMulti Portable Slim DVD Rewriter...
Tip
Windows system always restart
Computer often restarts, can not enter windows.<br /> Firstly check your ram.<br /> If you can, do a test with the new ram it's better.<br /> if not, make sure your use ram is fully functional.<br /><br />Turn on your computer, if the problem is still the same.<br />Do a test on your power supply. make sure the power supply to do the test is 100% work or use the new.<br /><br />Turn on your computer again, if the problem still occurs. unplug all cables connected to hard disks, cd / dvd rom, floppy and remove all the pci cards. now leave the connection to the power supply to the motherboard and the other connecting wayer suiz on / off (all the connections on the panel) if you are using a display card, left the display card in the slot and then turn on your computer.<br /><br />Now look at the results. if still the same. This means you need to do tests on your processor and motherboard. but if your computer does not restart again stable, this means, most likely the problem comes from the hard disk.<br /><br />Ok. now try to connect to your hard disk. problem occurs frequently restart <br />again right?<br /><br />If so, you need to perform tests on your hard disk. <br />how to perform the test, if you have important data in the hard disk. I suggest you first Copy your data to another computer first. by connecting the hard disk into the computer that you want to use to make copies (if the type of hard disk pata / ideas, set the jumper to slave and connect to any idea that the cable has not been used in the computer you use, if no the cable idea, you can use a cable that is used for cd / dvd ram for a while) if your SATA hard disk, no need to set jumpers, just connect the sata cable and then just copy the data may be at work to do.<br /> <br />After completion of all copied data. The cover page, then klik2x on my computer icon. observe the hard disk drive for. (For example, now for the hard disk drive is e. Right-click on the drive and click format. If the page to format mungul. Tick box format for quick and clear the volume level and then click Start.<br /> <br />after the format, remove the hard disk and set the jumper to the original and put it on your computer. then for the window installation process you will be done as usual.<br />** (If your problem still occurs. My suggestion is that you must use a new hard disk or a 100% hard work and re-do the installation window, because the hard disk is damaged or has a bad sector will cause your system files are always auto restart due -file to boot normally have been damaged or lost due to bad sectors.) **<br /> <br />good luck ... <br />Contact me for further problems<br /><br />Regards<br />multilinkent<br />Thank fixya<br /><br /><br />
on Feb 22, 2011 | Computers & Internet
My com has best defence against online threats, so i can't access internet, i tried basic connection like reset but it didn't work.. I couldn't make Lan network connection eather.. what...
Are you still having this problem? If so, uninstall Norton 360 and restart the system.
After restarting then setup Norton 360 do not add any additional apps into your computer until
it fully is installed and it tells you to restart the system.
If that doesn't solve the problem then get AVG Internet Security 2011 and it will help you to secure your system from hackers and viruses.
Let me know if the problem persists. Then the other thing is total format of the system and all data has to be backed up in Safe Mode. Do not do any thing other then backing up and formatting the system to a fully brand new partition and install Windows back on and do not connect to the internet till you get Norton or AVG installed once there installed then connect to the internet and see if that solved the problem.
After that install on the applications and then restart and login into your system and your all set.
Sep 15, 2011 | HP dc7700 PC Desktop
It will not boot in safe mode. It will not boot to last known good configuration. . On the blue screen "A problem has been detected and windows has been shut down to prevent damage to your computer. ...
This error refers to an inaccessable boot device. I typically will fix this error by booting the PC from another form of boot media (Example: Linux Ubuntu) to access the files. But to make it simple for any user, you will want to buy a replacement hard drive, that your system can support.
Cut power to the PC. Physically remove the damaged drive. Install the new replacement drive, and install your recovery CD to this drive. Once the system is back online from Recovery, you can re-connect the damaged drive, as a slave, to retrieve the data.
Most new systems will allow both drive to detect in the system if you set the jumper on the end to Cable Select (CS). If you have SATA drives, Master/Slave doesn't apply.
Beyond this point, if the drive will not allow access to the files, you will have to follow the same method, but try installing some free File Recovery Tools to scan the damaged drive with, like PCI File Recovery.
Contact me if you would like more detailed instructions sent to your email. You will have to send me a make and model of the PC though.
Aug 23, 2011 | Dell Dimension 8400 PC Desktop
Hi I posted a problem last night about my asus eee pc 1005ha... kept rebooting at windows load screen. so I brought a dvd burner to run windows disk & do repar. it would go through everything fine...
Hi.
Solving your problem is just as easy as 2 hour work. not more..
By the time you were having the restarting problems.. all you had to do was to boot from usb cd-rom using Hirenes boot cd 10.
It starts a small intergrated windows. then you would have to go to a menu to stop some un-named startup bugs that cause the restart when Explorer.exe is being executed by windows.
so now, if you have your backups safe, get instruction on the internet on how to make a bootable usb windows vista or 7 Setup. windows seven comes with many drivers for new laptops.
Boot your computer from USB flash disk, run the windows 7 setup and enjoy..
hope this information helps you because it helped me with Acer One netbook..
good luck
Nov 23, 2010 | Computers & Internet
External hard drive not recognized
You need to first narrow down the problem to either your PC or the external hard drive. Do you have access to any other PCs you could try connecting your hard drive to? (think friends, family, public PCs, etc)
If the hard drive works on other PCs, we know it isn't a problem with the hard drive.
If it turns out that the hard drive is fine and the PC is the problem, I would suggest going in to Device Manager and uninstalling everything USB related. Once you have done this, either reboot your PC or right-click inside device manager and "scan for new hardware". All of your USB related devices should reload their drivers automatically. You may want to try this both with and without the usb drive connected.
Another tip would be to try various USB ports.
Mar 19, 2009 | Western Digital 500GB My Book World...
My Presario 700 freezes up at random times
sounds like the following
Virus
Spyware
Devices or drivers are conflicting.
Hard Drive is failing
Step one
Disconnect the computer from the internet.
If this is the problem it is more than likley a virus or spyware
If it still freezes proceed to step 2
Step 2
Restart Computer in safe mode, do not connect to the internet.
To restart the computer in safemode turn on computer and press F8 continuosly until a screen of options comes up.
Select Safemode without networking
If computer still freezes up proceed to step 3.
For windows XP
Locate the My Computer Icon and open it. Locate Local Disk C: Or whatever harddrive that has windows installed
RIGHT Click it. It will then open a menu of options, select properties. At the top select tools tab. Click the check now button.
A new window will pop up, check both boxes and press start.
Another window will pop up select yes and restart the computer. Do not press anything and let it work.
Considering the age of you computer it is probably the hard drive in which case should only cost about $45 for another one. search for a harddrive that fits your model on ebay or another trusted site.
It is not very difficult to change the hard drive so dont panic.
Mar 06, 2009 | Compaq Presario 700 470024-192 Notebook
Computer won't boot into windows
The event of you inserting a DVD is unlikely to have anything to do with this problem. Probably just a coincidence that it happened after you did so. Hard drives die eventually and more frequently so in laptops.  I'm afraid you will have to bite the bullet and replace the hard drive.
Dec 11, 2008 | Dell Inspiron 300M Notebook
Dell Dimension 2400 Freezes frequently
check inside the case of the computer to make sure that the interface cable between the hard drive and the motherboard are fully connected. Also check to see if the RAM modules are fully inserted into their slots. If not, they try removing them one by one, until the computer starts up faster. If this doesn't fix it, then try a new hard drive, and interface cable.
Feb 21, 2008 | Dell Dimension 2400 PC Desktop
Fujitsu Sacaleo 600 boot problems
sallyb
Your registry is needs fixing.
PC's today get cluttered with more damaging data, junk, and extra files than ever. This results in poor PC performance, frequent system crashes, slow Internet connections and worse. Fortunately there are some great software downloads that you can use to fix things.
You can do two things.
1. download a registry fixer, which would be difficult for you to do since your system cannot restart.
OR
2. Reinstall your operating system. restart your computer and while it is restarting hold down the delete button. It will bring up your bios. there you can then go into your c-mos setup and change your boot settings to BOOT FROM CD FIRST. THEN HARD DRIVE..
When you finish that, press F10 to exit and save settings.
Ten insert your windows disk and restart system. Reformat the entire drive. (NOTE: YOU WILL LOSE YOUR INFO). OR you can tell it to repair .
My advise to you is when it is finish repairin. backup all your important files and follow step 2 but this time you would want to reformat the Hard Drive. (that is to wipe it clean and reinstall windows fresh.
Please let me know if this help.
Nov 16, 2007 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
Lenovo ThinkPad X100e (350829U) PC Notebook Logo
35 people viewed this question
Top Lenovo Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
