Maytag CWE5800A Electric Double Oven Logo
Posted on Feb 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Instructions to set cooking time on and off - Maytag CWE5800A Electric Double Oven
Mike Cairns
Level 3:
  • Maytag Master 3,054 Answers
  • Posted on Oct 28, 2011
Mike Cairns
Maytag Master
Level 3:
Answers
3054
Questions
0
Helped
850887
Points
6358
Hello, pb
I was trying to help you out here. Maybe this will help some? I was going back to some customers that asked questions in the recent past and even farther back. It appeared that no one answered some of them, So, I thought I would take some of my personal time to see if I can help. Even though this Informational site may not have your exact model or brand, this site will help you a lot. Here is a site link about everything you want to know about ovens and possibly yours, from
repair to trouble shooting it. Now go easy on me, I am just trying to help. If it does great if not, I am sorry.
http://home.howstuffworks.com/how-to-repair-an-oven.htm
Please if this helped you at all, if you can find the time and in your heart to rate my help and some kind words written would be appreciated for my free help , I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive, Appliance, and Electronics. Drop In anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
I need an instruction manual for a red centre outdoor gas oven
Instructions Things You'll Need:
  • Power supply
  1. Press the "Clock" button, then the correct number buttons to set the desired time. Press "Clock" again to confirm.
  2. Press "Timer" to set the timer function. Choose the desired countdown time by pressing the number pads, then the "Start/Stop" button. Press "Timer," then "Reset" to cancel the timer.
  3. Press the number pads to select a cooking time. Press "Power" to use a power less than 100 percent using the number "9" for 90 percent of full power, "8" for 80 percent, "7" for 70 percent, and so forth. Press "Start" to begin cooking.
  4. Press "Defrost by Weight" to defrost a food item by the weight of the item. Enter the weight of the item, then touch "Start" to begin. Enter the food weight by pounds and ounces, using a "0" for a decimal. For instance, if the food weighs 1 pound, 2 ounces, enter "1," "0," "2," then "Start".
  5. Select "Speed Defrost" to defrost food quickly. Enter the desired cooking time and press "Start."
Dec 21, 2010 • Ovens
How do i set the time on w westinghouse pgn659s wall oven?
Instructions below.
  1. 1 Fill the insert of the Corningware slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
  2. 2 Press the "On/Off" button on the left side of the electronic control panel in the front of the appliance. This will turn on the slow cooker to the low heat "Warm" setting.
  3. 3 Press the "Cook Time" button on the right side of the electronic control panel to add hours to the timer which will show a total time in hours with a red digital display. Continue to press the button until the display indicates the desired cook time in one-hour increments up to 10 hours. The cooker will automatically adjust the temperature setting based on the amount of time you programmed on the timer. Cooking times of six hours or less automatically start on "High" heat and times of seven hours or more will start on "Low" heat. A small indicator light will come on below the word to tell you the cooking temperature.
thank for visit.
Oct 09, 2010 • Ovens
Resetting the clock
You can set the timer on a single oven slow cooker to automatically switch to a warming setting when you estimate foods will finish cooking.The programmable features allow you to leave food stewing at home while you are out of the house, freeing up your day. Set the timer on a Corningware slow cooker to let the kitchen appliance do all the work, and come home to a fully cooked meal.
INSTRUCTION BELOW.
  • Fill the insert of the single oven slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
  • 2 Press the "On/Off" button on the left side of the electronic control panel in the front of the appliance. This will turn on the slow cooker to the low heat "Warm" setting.
  • 3 Press the "Cook Time" button on the right side of the electronic control panel to add hours to the timer which will show a total time in hours with a red digital display. Continue to press the button until the display indicates the desired cook time in one-hour increments up to 10 hours. The cooker will automatically adjust the temperature setting based on the amount of time you programmed on the timer. Cooking times of six hours or less automatically start on "High" heat and times of seven hours or more will start on "Low" heat. A small indicator light will come on below the word to tell you the cooking temperature.
  • Please rate this solution after use.
    Thank you and thanks for using fixya.
    3helpful
    I need the instructions for a diplomatic double fan oven as the second oven is set on auto timer and I can't get it to work.
    i had the same prob..... manual operation, to set the programmer to manual (cancelling any auto setting),press the cook time and ready time buttons simultaneously.
    To set time of day, press the cook time and ready time buttons simultaneously and keep the buttons depressed. Use the plus and miuns buttons to the the time. A(auto symbol goes out cookpot symbol comes on.
    Mar 27, 2009 • Ovens
    1helpful
    Delay or time bake
    You can find the manual at www.managemyhome.com, and the instruction is on page 11.
    You make sure the time is set correctly.
    You press Bake, and set the temperature you want to bake.
    You press Cook Time and enter the amount of time you want the oven to cook.
    You press Delayed Start, and enter the clock time that you want the oven to start.
    How to set the timer
    1. Set the oven to the required
    temperature.
    2. Press the g button.
    3. Set the total cooking time with the +
    button (see the example in the
    illustration right, showing 1 hour and
    30 minutes).
    4. Press the h button.
    5. Set the cooking finish time with the +
    button (the example in the illustration
    shows 12.30 hrs.).
    After setting the display shows the
    time of day and indicates »AUTO«.
    The oven cooling fan will start
    immediatley.
    At the pre-set time, the oven will be
    automatically switched ON.
    The settings can be corrected at any
    time.
    When the pre-set cooking finish time
    is reached, a signal sounds and the
    oven is automatically switched OFF.
    To turn the signal off, briefly press the
    h button.
    6. Turn the oven selector switch to the
    0 position.
    7. The »AUTO« symbol blinks.
    Important: It must be switched OFF
    by pressing the E button.
    Also here is the manual.
    https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
    Good Luck
    Setting the oven to come on at a certain time
    I have a neff u1722 but I think the settings are pretty much the same. To set a coming on time first press the button with side by side triangles on it until the symbol l->l flashes then rotate the plain button next to it to the length of time you want the food to cook for. After about 4 secs the normal time will come back on. Then press the side by side triangle button again until the symbol ->l flashes then with the plain button rotate again to set the time you want the food to be cooked for. Hope this works
    12helpful
    2answers
    Creda europa solar plus double oven
    Hi, hold down the minute and cook button and at the same time hit either the plus or 1 button to set a time and then oven will work. each time the power is off this needs to be done. hope this helps
    Dec 02, 2008 • Ovens
    56helpful
    Diplomat Oven ADP3650 Instructions
    User manuals are hard to find.
    The problem I had was setting the clock on a single Diplomat oven, with no clock button. Here's my solution :
    DIPLOMAT OVEN OPERATING INSTRUCTIONS
    The Diplomat single oven is controlled by two knobs and a set of buttons along the middle of the control panel.
    The left knob sets the temperature of the oven, while the right knob selects the function to be performed, e.g. fan oven, grill, etc.
    The buttons along the middle set the cooker clock, the start and end times of cooking, and the “+” and “-“ buttons will increase or decrease the time shown on the cooker’s clock.
    PLEASE NOTE THAT THE OVEN WILL NOT OPERATE UNTIL THE CLOCK IS SET.
    If there is any interruption to the power supply (including manually switching off at the main switch) the oven will not operate until the clock is reset.
    Here’s how to set the clock:
    First press simultaneously the first two buttons to the left of the control panel. They are marked as a Bell symbol (Alarm) , and a steaming Cooking Pot (Start of Cooking Time). Then immediately press the plus “+” or minus “-“ buttons to increase or decrease the time displayed. When the desired time has been reached, leave it for a few seconds, and it will remain set at this time. Any further changes to the displayed time will require this procedure to be repeated.
    Hope this helps!
    Oct 10, 2007 • Ovens
    Top Maytag Ovens Experts
    Mike Cairns
    Mike Cairns
    ZJ Limited
    ZJ Limited
    Paul Carew
    Are you a Maytag Oven Expert? Answer questions, earn points and help others
