Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Logo
Anonymous Posted on Feb 20, 2011
My whirlpool cabrio front load dryer will power on but when you press start it doesn't. All it will do is light up under "sensing" but never moves on to actually dry the clothes. I have checked the breakers as well as unplugged and plugged the dryer back in. No error code pops up...just the timer. Any ideas?
Tim Whalen
Level 3:
  • Master 3,076 Answers
  • Posted on Feb 20, 2011
Tim Whalen
Master
Level 3:
Answers
3076
Questions
0
Helped
824461
Points
9577
Underneath the lint trap is a sensor, it will need to be cleaned. Good luck Tim
  • BloodRaven Aug 18, 2011
    There is no Sensor. We have taken it apart and looked at the manual the Cabrio has no lint sensor
  • Luz kilgore
    Luz kilgore Mar 03, 2014
    I have a Frigidaire gallery series with an error code loc how can I fix this
3 Related Answers
Anonymous
  • 109 Answers
  • Posted on Aug 23, 2009
SOURCE: my dryer dries for a short period time and senses
no. what you are getting is an over heat sense and is shutting the unit down this is a safety type of thermostat and will shut down the heating cycle prematurely as it will with a clogged vent or lint filter
TheMobilian
Dan Webster
  • 8221 Answers
  • Posted on May 22, 2010
SOURCE: whirlpool duet dryer - when using the settings
Easy fix: Look inside the drum below where the filter goes in. You will see two metal strips. They sense the wetness. Now get this: the dryer sheets rub against them and a thin wax buildup on them prevents the controls from properly determining wetness. The control has no clue the clothes are still damp and thinks everything is kosher; so it advances to the end. Solution. Clean the stuff off of the sensors so that they can sense the true wetness once again.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Anonymous
  • 43501 Answers
  • Posted on Aug 21, 2011
SOURCE: My whirlpool cabrio front load dryer will power on
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Turn on power, the lights come on but when you press start nothing happens just a click sound.
Click sound at power button and start button should get it going. If not then Dryer drum is not turning.
Whirlpool Cabrio dryer won't start - the sensing light stays on
An EXTREMELY helpful technical guide is folded inside the console housing.
WARNING: It is for appliance techs, DO NOT do the voltage/resistance checks if you are not well-versed in troubleshooting appliances! BUT, it does include putting the dryer in diagnostics mode and checking the sensors.
Post back any error codes you may get.
My whirlpool cabrio front load dryer will power on but when you press start it doesn't. All it will do is light up under "sensing" but never moves on to actually dry the clothes. I have...
heatman101
6helpful
Whirlpool Cabrio Dryer Wont go past sensing light when I press start. The door is tightly closed and the filter is clean. It just won't even try to start it just just beeps once.
my dryer sensing light was on and dryer would not start, we replaced the sensor fuse and now it works the fuse is in back of dryer close to the bottom on the left hand side very easy to replace cost $11.00 by the way don't call whirlpool they have no clue, wanted to send repair man out to fix it.
35helpful
2answers
Whirlpool cabrio steam electric dryer has sensor light on and does not work
have a problem with my cabrio dryer its powered on but when i push start the sense like comes on and does nother whats the problem
2answers
Another Whirlpool Cabrio Sensing issue
Hi-- none of the solutions I've read here are working. Same problem, dryer not starting, it says "Sensing..." and then "Wet" and does nothing. It worked fine on the last load, except I noticed it read 11 minutes for a very, very long time (I think it got stuck). New load? "Sensing..." etc.
245helpful
4answers
Whirlpool duet dryer won't start
whirlpool duet dryer has power but will not start--when I press start, it beeps once and the sensing light comes but the dryer doesn't start
Top Whirlpool Dryers Experts
Virgil Watts
Paul Bade
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
