Minolta magicolor 2400W Laser Printer Logo
Keith Larter Posted on Feb 19, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I start up printer after it rotates the toner cartridges the error light comes on and cannot be cleared . On my Windows computer it says there is no cyan toner cartridge. There is, of course.
Norman Weimar
Level 3:
  • Minolta Master 7,035 Answers
  • Posted on Feb 22, 2015
Norman Weimar
Minolta Master
Level 3:
Answers
7035
Questions
Helped
1910642
Points
11959
Does it say Image Cartridge or toner. Is the cartridge third party if so replace with a real Minolta cart the machine do know info on the chip on the cartridge and reject them sometimes
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
5 Related Answers
john archer
  • 186 Answers
  • Posted on Jun 29, 2007
SOURCE: toner problems
A couple of suggestions. 1. make sure there is not any plastic shipping tabs that need to be removed from the cartridge. 2. try reseating the cartridge. 3. Try replacing that cyan cartridge. It may be defective. Also make sure you use Minolta brand toners!
Anonymous
  • 3 Answers
  • Posted on Jan 14, 2008
SOURCE: Sensor Error
About the croaking noise:
The drum unit, underneat the toner cartridge, at the left side (seeing the machine from the front) has a kind of a pump device, made with an internal small belt (you can't disassembly it), its function is to move the old used toner, that exit the cartridge from the left hole, into the springed plunger, the toner moves into that chamber and is pumped back into the cartridge. In time that chamber receives so much old toner that the small transporter belt inside can't move anymore, it makes a very high load to the pulleys and they jump tooth, so the noise. You may want to disassembly the drum unit, (as reference the yellow p/n is 42126601), and get isolated just that chamber, there is only one small plastic geat that moves the pump inside. The gear must rotate somehow free, if not, try to such old toner using a vacuum cleaner, but you will need to keep rotating the gear by hand to pull out all the bad toner. It may exit from the bottom hole or from the spring loaded plunger on top (when pulling the spring). If you are lucky you may have it working back again, if not, prepare your dollars bills to replace the unit. The croaking you are listening may be cause by this or it may be a wrong drum unit you installed into the machine. Check the gears between the old and new units. Good luck. Wagner.
Anonymous
  • 214 Answers
  • Posted on Jun 19, 2008
SOURCE: Rotate Toner Button and Replace Cartridge Messages
Hello
take out all toners and pc drum, use pressure air to clean chip reader under the toner rack (right side) also use some alcohol to clean chips on toners and reinstall.
Anonymous
  • Posted on Jun 30, 2008
SOURCE: changing toner cartridges
Go to reset menu on printer LCD Panel
Hit enter button
Scroll down until you get to the "Change Toner M/C/Y/K" hitting the enter key when you get the appropriate letter.
This will rotate the appropriate cartridge to the opening!
Anonymous
  • 214 Answers
  • Posted on Jul 01, 2008
SOURCE: Toner Not Installed - After replace black
pleas clean toner chip reader, remove pc drum and all toners, under the toner rack there is a 3 pin chip reader, use pressure air to clean it. if the new BK toner is not original, it will say only not genuine toner but will print.
1helpful
Red light
Error Red On
• The cover is open. Close the cover.
• There is no paper in the tray. Load paper in the tray.
• The printer has stopped printing due to a major error.
• The toner cartridge is not installed. Install the toner cartridge.
• Your system has some problems. If this problem occurs, contact your service representative.
• The toner is totally exhausted. Remove the old toner cartridge and install a new one.
Error Red Blinking
• A minor error is occurring and the printer is waiting for the error to be cleared. When the problem is cleared, the printer resumes printing.
• The toner cartridge is low. Order a new toner cartridge. You can temporarily improve print quality by redistributing the toner.
Lexmark c534dn unsupported cartrige
This error message appears on the printer screen when the printer thinks the wrong toner cartridge is installed. To clear it or identify a service requirement, follow the steps below. NOTE: If you succeed in resolving the problem at any stage during the procedure, you not need to perform the remaining steps.
  1. Open the top front cover of the printer. If the display DOES NOT read Close cover or Insert cartridge, the 32 error is not caused by the toner cartridge and printer service will be required to fix the problem.
  2. Make sure the correct toner cartridge is installed for this printer model.
    1. Check Lexmark for a list of compatible cartridges for your printer.
    2. If the wrong toner cartridge is installed, remove it and install the correct one.
  3. If the correct toner cartridge is installed, it may not be seated correctly. To ensure that this is not the cause of the error, do the following:
    1. Turn off the printer.
    2. Reseat the toner cartridge.
    3. Close the lid.
    4. Power the printer back on and check the display.
  4. If reseating the toner cartridge does not clear the error message and the error started as soon as you installed this particular toner cartridge, the cartridge may be broken. You can check this as follows:
    1. Power off the printer and then reinstall the old cartridge. (You can also try a different new cartridge to see if that clears the error.)
    2. If the error does disappear, the problem may lie with this cartridge. Please contact the point of purchase, especially if the cartridge is brand new out of the box.
  5. If the error cannot be cleared by putting in a new toner cartridge or one that is known to be working, the printer may require service to fix the problem.
3helpful
Minolta di250 error code c0070 this error code
This service code C0070 is a universal code used by Konica Minolta to indicate a toner bottle rotation failure. These machines add toner by rotating the toner bottle that you install in the machine. Most of the time this code is caused by a toner cartridge that has been installed incorrectly or has become dislodged from it's holder. To clear the code open the toner door and remove the toner cartridge/bottle from the machine. Close the toner door and turn the machine off then on to reset the code. Let the machine run. This may take several minutes and will allow the machine to bring the toner bottle receptacle into it's home position. Once the machine stops running completely, then you can re-install the toner cartridge. If the code does not come back you are ready to go. If the code came back after removing the toner but before you re-installed it then you have either a dirty rotation sensor or a bad toner drive motor and will need service.
If the code comes back after the cartridge is re-installed then there is either a priblem with the cartridge or with the toner bottle drive.
Most of the time though the problem will be resolved by the outlined procedure.
Good Luck and Thank You for using Fixya.
3helpful
HOW DO I FIX THE ERROR 004-332...???
1. Reseat and clean the 4 toner cartridges and verify the orange plastic covers have been removed.
2. Reseat the toner cartridge carousel position. By doing the following:
Lift the handle of the first available toner cartridge or toner cartridge attempting to be installed and remove the toner cartridge.
Close the front cover. Power off the printer. Power on the printer.
An LCD message Insert <toner color> Toner appears. Open the front cover. To reinstall the toner cartridge, align the arrows on the cartridge with the corresponding arrows on the printer, guide the cartridge in until it snaps into place, and then push down the right lever to lock the cartridge in place. Close the front cover. The toner cartridge carousel rotates to the correct toner position.
3. Verify the developer rotor frame is not bent. If it is bent then the printer should be replaced, it would not be cost effective to replace the frame.
4. If it is not bent. Open the front door, try to rotate the carosel. It should NOT rotate. If the rotation is rigid and feels broken, then the printer should be replaced. If it rotates smoothly, the developer latch should be replaced. If the carosel does not rotate but still gives the error the rotor control board should be replaced.
Toner problems with Konica Minolta 2450
very annoying message i agree - most likely caused by toner dust.
The printer uses a carousel to rotate the toner cartridges. Dust and toner can easily spill as the cartridges rotate. The error can appear at any time but seems to be most annoying after a paper jam or other error. It is also important to make sure that the cartridges themselves are clear of toner dust. Pay particulair attention to any copper contacts on the cartridge.
http://www.zinetic.co.uk/toner_refill/magicolor-sensor-errors.aspx
I have replace the yellow colour and ever since the printer comes up with a error saying no toner
this is a very annoying error message
Konica Minolta Magicolor 2400/2500 series printer "X cartridge not installed" One of the most frustrating features of the Magicolor 2400/2500 series of printers is the very annoying X Cartridge not installed message
This error message can occur at any time with both original cartridges and or refilled cartridges. It is caused by either toner / paper dust covering either the chip on the toner cartridge or dust covering the chip sensor inside the printer. It can also be caused by a faulty chip reader inside the printer.
5helpful
Samsung printer ML 2510 series
Maybe the toner is low... According to the manual, a blinking red light:
printing.
by redistributing the toner. See
page 8.3.
and install a new one. See page
8.4.
• The toner cartridge reached the
end of its life.
Lexmark E238: Lost manual. What does second light from bottom mean? Printer won't start.
could mean that it a mismatch carteridge
  • Explanation of the Cartridge Mismatch error
  • Clear or Confirm the Error Message
  • Check the Printer and Toner Cartridge Region Settings
  • If the Toner Cartridge and Printer Regions Do Not Match...
  • If the Toner Cartridge and Printer Regions Match
  • 1helpful
    2answers
    How to remove the toner cartridges
    Close the cover to the machine and make sure you aren't getting any other error messages other than the toner. When the printer is at the ready state press the rotate toner button. You should hear the printer rotate the toner and then the light over the cyan cartridge will come on. Keep pressing the rotate toner button until you get to the color you want to replace. Open the top cover and front door where the KM logo is. You should see the cyan cartridge in place. Pull the cyan tab back toward you. The front part of the toner should release. Now pull the tab and the toner straight up and out of the printer. If you are having problems getting the toner out it is probably not in the correct position. There is a slot on either side of the printer that he back end of the toner cartridge needs to be in before the toner will come out.
    Top Minolta Office Equipment & Supplies Experts
    Norman Weimar
    Norman Weimar
    ZJ Limited
    ZJ Limited
    Daniel Blask
    Daniel Blask
    Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
