Question about Sony Cyber-Shot DSC-S90 Digital Camera
When i turn off my camera sony cyber shot DSC-S90 the zoom wont retract and a word appear in the screen turn off and on again..any idea what's going on with it?
Posted by ragdesanipil on
John smeed
  • 29 Answers
Sounds like you have some grit or gum on the lens barrel. This will cause the lens to stick in the partly closed position. Clean the lens barrel and try again. A rag moistened with methylated spirits may be needed. The rag must not be wet as we must not harm the special grease used in the lens.
If this fails it probably means an very expensive repair, or replacement.
Posted on Feb 19, 2011
29helpful
2answers
When I turn on sony cyber-shot camera I get a screen display that states "access". The lens keeps going in and out and then it states,"turn the power off and on again" What's...
When I turn on sony cyber-shot camera I get a Problem with the Sony Cyber-shot DSC-W35 Digital Camera when I turn on sony cyber-shot camera I get a screen display that states "access". The lens keeps going in and out and then it states,"turn the power off and on again" What's wrong??
Sony Cyber-Shot DSC S90 lens problem - fix or buy new?
its better to replace a new one than to repair it and besides you will cost alot if you decide to repair it. although if the cost is not that much then go for repairing it.
CHARCOIS
I have a sony dsc-s90. It will work fine for 3 - 5 min. and then a black screen will appear with "turn power off and on again". Once done, it happens again.
Usually a lens sensor. Clean with maybe some compressed air. If you trust your skills you could open the unit and clean cabinet where the lens retracts and extends.
3answers
When I turn on my Sony Cyber-shot DSC-W35 the screen is dark with the word "Access" on it, moments later it tells me to power it off adn on again, any ideas?
Its lens error in your DSC-W35 camera.
Lens mechanism is either stuck or not retract completely and system control sense this error. Please replace lens assembly to get it fixed because lens mechanism is not repairable.
Thanks.
My dsc hsx-1 zoom lens wont retract from max.
my cam z sony DSC HX1..the problem z when i zoom in(max) the objct i m zoomin doesnt get focusd....when i shoot it the pic z totally blurrd....no matter how mch i try 2 focus with the manual focus option the outcum z da same....
The zoom lens does not retract on dsc-w1/w12
I've had the same problem on rare occasion. Usually, I just wait a few seconds, then turn the camera on... wait a few more secs, turn off... repeat as necessary. When all that doesn't work, I've replaced with new batteries & the problem is solved.
Will not power on properly
For what its worth I had this same problem with both rechargeables and alkcalines. Fresh batteries were rejected after just a few shots and were clearly NOT dead. Solution seems to be either use Sony's NP-NH25 cybershot battery which is made of two AA batteries jointed at the hip or use generic rechargeable NiMh batteries with a capacity superior to Sony's battery (>2500mAh).
Dan
5helpful
2answers
Sony Cyber-Shot DSC-W30. The lens is in a "stuck" position
You have a bad lens, it prob. also says turn off and on again.
2answers
Cannot Take Pictures Anymore...
Hey BLOBO123,
I would have the camera looked at by an authorized service technician. You could bring it to a Geek Squad® precinct in a Best Buy™ store and they can send it out for service. The flap that holds the batteries in could possible be purchased from the manufacturer and is probably pretty easy to replace, but the lens is usually much harder and expensive to repair. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
2answers
Lens will not retract and no view on back of screen
possible bad lens assembly.These can only be replaced try alamo camera service .com
Sony Cyber-Shot DSC-S90 Digital Camera Logo
Top Sony Cameras Experts
Vish Iyer
Vish Iyer
Rehan Zafar
Rehan Zafar
Are you a Sony Camera Expert? Answer questions, earn points and help others
