Http://support.eu.square-enix.com/faqarticle.php?kid=59049&ret=main&id=2147&la=2&pv=20&SQEXSC=f7do7u05ncttoh4rt9gl19amp6
KB Article: 59049
KB Category: [Technical Support]
KB Sub-category: [ Installation]
I cannot install the Tag?s driver on Windows Vista and the game will not run wthout them, what can I do?
Infernal
is copy protected with \Tag?s\". This requires you to install a Tag?s
driver which is found on the game disc and should be installed when the
game is installed.
Unfortunately the Tag?s drivers on the Infernal disc have not been Vista
certified. If you are using Windows Vista you won't be able to install
the Tag?s drivers and to start the game. You need to download and
install the following certified drivers:
http://www.tagesprotection.com/main.htm?page=5.5.htm
Apologies for any inconvenience.
FYI THIS IS A FIX FOR WIN 7 as well x64 and x86
SOURCE: When starting anno 1701 I
i have exactly the same problem as you but before it worked fine on my older laptop. i dont know what is causeing the problem or how to solve it, but i am looking the best i can for a sollution. if i find a solution ill inform you asap.
Pentium4 1,7 GHz
