Texas Instruments BA II PLUS Financial Calculator Logo
Anonymous Posted on Feb 19, 2011
I would like some help in solving some TVM problems using the BA II Plus calculator. i.e. How to solve: I invested a lump sum of $2400 in an investment that returns 6% annually. How much will the investment be worth after: a) 1 year b) 5 years c) 10 years d) 30 years
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Texas Instru... Master 102,366 Answers
  • Posted on Feb 19, 2011
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10442880
Points
622693
2nd [CLR TVM] (clear TVM registers)
2 4 0 0 +/- PV ($2400 initial investment, negative because you're paying it out)
6 I/Y (6% annual interest)
1 N (one year)
CPT FV (compute future value, see 2544.00, the value after one year)
5 N (five years)
CPT FV (see 3211.74, the value after five years)
1 0 N (ten years)
CPT FV (see 4298.03, the value after ten years)
  • Anonymous Feb 19, 2011
    Thank you so much. I actually managed to compute the answer on my own while I was waiting and am grateful for the reinforcement that I have done this correctly. I will have more and look forward to the help.....you should only know the pressure I am under.
    Again thank you so much.
BA-II Plus Calculator not giving correct answers to standard equations.
Download the Guide of Calculator form Texas Instruments official website BA II PLUSâ„¢ Guidebook - Texas Instruments - US and Canada (ti.com) and refer to page 82 (Reference Information)
FV wrong answers
Were you also clearing the financial memory with 2nd [CLR TVM], or just the storage memory? If you don't, it's going to keep using whatever value you last used for PMT.
2helpful
How to calculate on BA-II Plus the number of annual compounding periods
Actually, you don't need the y^x key.
Clear the financial registers with 2nd [CLR TVM]
Enter the present value: 1 0 0 0 0 0 0 +/- FV
Enter the future value: 2 0 0 0 0 0 0 FV
Enter the interest rate: 7 I/Y
Compute the number of periods: CPT N
Error 1 or error 5 while solving for TVM problems.
According to the manual, error 1 indicates "Overflow", a number whose magnitude is greater than 9.9999999999999E99. Error 5 indicates "No solution exists", for example when FV, (N*PMT), and PV all have the same sign.
If you still have trouble, please feel free to reply to this post, giving sample problems producing these errors.
I would like step by step instructions on how to solve a simple TVM equation. i.e. I invest a lump sume of $2400 in an investment that returns 6% annually. How much will the investment be worth after ...
GOOD QUESTION, Patweetyp...
I've got you covered.
Seeing how it's been three weeks since you posted this there's a chance you've already gotten your answer, but let me go ahead solve this for those out there who may have had the same problem.
Background: There are FIVE TVM Keys; and as you would assume, you MUST input FOUR of them in order for the BA II Plus to solve for the fifth. Now let's get down to business.
1. Hit CLR TVM. [This is just a cleanup maneuver]
1a. Hit ENTER [yes, BA II Plus always needs to be told to store the value, ALWAYS]
2. Type in -2400
3. Hit PV [Since you are investing money at time 0, your present value is negative 2400]
3a. Hit ENTER
4. Type 6
5. Hit I/Y [Your annually compounded interest rate is 6 percent]
5a. Hit ENTER
6. Type 0
7. Hit PMT [you do not have any recurring deposits*]
7a. Hit ENTER
8. Type 1
9. Hit N [there is one year until expiration/liquidation/termination]
9a. Hit ENTER
10. Hit CPT
11. Hit FV [this is your ANSWER = 2544]
----- From here, all you would need to do is change N in order to get your other answers (5 years, 10 years, etc) ----
*If your calculation does not require a recurring payment then you really just have a basic equation of value which would be solved faster by hand. (IE, 2400*(1.06)^1=FV=2544).
You'll notice that I underlined "annually compounded" as well as "one year". The reason for this is because you ALWAYS need your interest term to match your time interval. For instance, if you had monthly payments of which you wanted the year-end total you would need a monthly effective interest rate, and N would be 12.
Okay, I hope that helped. The BAII Plus is the best calculator for time-value-money calculations I've come across. When things get more advanced, you will start using the amortization table which cannot be found in any other TI Calculator (from what I know). TVM is perfect for annuities, mortgages, loans, bonds, and more.
[email protected] for more questions.
TEXAS INSTRUMENTS = 1-800-TI-CARES...they are friendly.
I am trying to calculate the number of periods - solve for the unknown number of years PV 625 interest 8% fv 1284 how do I calculate using the calculator
2nd [CLR TVM] (clear old data)
6 2 5 PV (present value)
8 I/Y (annual interest)
1 2 8 4 +/- FV (future value)
CPT N / 1 2 = (compute number of months, divide by 12 to get number of years)
1helpful
My TI BA II Plus is returning incorrect answers for TVM problems... Is this common and can it be fixed?
It's more common that one of the settings is not correct. Check the BEGIN/END setting, the number of payments per year, and the number of compounding periods per year.
If you still have problems, please give an example of a TVM problem, with your results and the correct result. Simply saying "incorrect results" doesn't let anyone help you.
2helpful
My TI BA ii plus calculator is calculating the incorrect answer for a TVM problem. What is wrong?
Before each calculation of a TVM problem you must fully clear the calculator ... Press [2ND] [CPT] [2ND] [FV]
Best of luck
Haveing trouble getting the IRR using the BA II plus advanced business analyst. i am punching in the pv, fv, plus/minus pmt, and n. them computing the I. keeps giving me the wrong figure. The pv is 0, fv=...
I get 6.085%. Make sure the fv and pmt are of opposite signs. You're either making annual payments and getting a lump sum back at the end, or receiving annual payments and then paying it all back in a lump at the end. Either way, the money is moving in opposite directions.
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
