Question about LG Flatron 775FT 17" CRT Monitor
Color red is gone - LG Flatron 775FT 17" CRT Monitor
Posted by maryscottpla on
Liviu TURCU
  • 1,027 Answers
The data cable is interrupted
Posted on Feb 19, 2011
Hello, my video card is nvidia geforce 6150 le and the red color is gone, thank you for your help.
You should be able to adjust the color balance for the card. There will be software on your machine that allows you to set the color balance and other things. Usually there is at least some red However if the red is totally gone then it could be a problem with the cabling/connector between the desktop and the monitor, like a loose pin or wire. It is possible that it may be the monitor that has the red out. So first check your connections and your color balance. If that seems ok then try another monitor before you go further. If a different monitor has the same problem (with different cabling too) then you will know.
Aug 16, 2011 | HP Compaq Presario SR2020NX PC Desktop
My E771 monitor colors suddenly shifted with
Possibilities:
1. video-card gone bad;
2. video-cable gone bad;
3. video-cable not tightly-connected to CRT;
4. video-cable not tightly-connected to video-card;
5. "red" gun inside CRT gone bad.
Disconnect the video-cable from the computer, and try again to adjust the "red". If red-free, then it's time to responsibly recycle the CRT.
Reconnect & wiggle the video-cable, to see if that induces any "red" onto the CRT.
Connect the CRT to the VGA-output port on a notebook computer, to see if that video-card generates "red" as one of the primary colours.
Give the CRT a strong "whack" on the side, to see if "red" makes an appearance.
May 07, 2010 | ViewSonic E771 17" CRT Monitor
HI,the color on my monitor has gone blueish its like
try reseating or/replacing the cable. If the connection isn't good then you can lose one of the three basic color channels resulting is a tinted screen color
Jan 08, 2010 | Acer AL1916B 19" LCD Monitor
Color
Check the red colour out put section at LCD base PCB..the capacitor is weak or the transistor is gone bad,replace with new one..
Jul 09, 2009 | Samsung PCL541R 54" Rear Projection...
Screen gone yellow and green
I have a 21'' NEC TV Screen and it about 3 year old. the colour has gone to yellow and green color and the red etc
May 10, 2009 | Samsung PPM42S3 42 in. Plasma Television
How to apply color to start menu and taskbar in windows vista
These little things can drive you crazy...so let's go...Right click in an open area of your desktop-at the bottom of the box that opened- click on Properties then- Appearance tab- under Windows and Buttons- select -Windows Classic style. Now in the -Color scheme- select Rose or whatever color you like...then click on Apply and then OK.
I think you are missing the Apply and then OK.... this will do it for you, Enjoy your world of Roses..bye
Mar 21, 2009 | Dell Inspiron 1525 Laptop
Why is the color red is gone
this is because of the color control circuit for the red , its most likely an IC that controls red has failed or even a bad resistor , capacitor , ect .. in that circuit will need replacing
Mar 06, 2009 | JVC AV-27530 27" TV
My red is gone
there is color tracking problem in the tv. probably the tv is loosing the drive for one color, I will say the blue color
Aug 06, 2008 | JVC AV-27D303 27" TV
Red color gone on tv?
is the red gone on all inputs? do you have the tv hooked up, to a sat box, cable box via component video (Red, blue, green connections)? if so check the red cable on both ends.
Jan 29, 2008 | Zenith D52WLCD 52" Rear Projection...
LG Flatron 775FT 17" CRT Monitor Logo
Top LG Computers & Internet Experts
Ekse
Lee Hodgson
Lee Hodgson
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
